Anybody know the capacity of power steering fluid on 2005 Corvette?
thats a good question? probably wont find it because the Z51 and Z06 have remote coolers and hold more, my guess is if you have a neither of those look at around a quart and a half to 2 (thats just a poke at your question tho). While filling fill the reservior up put the cap on and rock the wheel lock to lock. Do this a few times till the air is gone and the yelling stops. Tech tip:much easier to do if the front wheels are off the ground. Good luck and pm me if you need a hand
i would sy thats pretty close. The pump and reservior hold around a pint or so the rack maybe 3/4 of a quart and the lines who knows but in the 1 1/2 t o2 quarts is in the ball park i think (insert fingers crossed here) maybe someone who has changed there rack would get you closer
Received 2,051 Likes
St. Jude Donor '13
My 2009 Service Manual says up to 4 quarts for a good flush, so actual capacity is somewhat less than that.
