** 60 LED "Switchback" Daytime Running Lights in Stock!***
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Switchback on right side of the car in the pic (cars left)
Video
Enhance the front of your C6 with our 60 LED switchback DRL bulbs.
These run way cooler than stock so no worries of burned housings and even look better.
Comes with 1 year warranty and your satisfaction is guaranteed (don't like them return them)
You can expect your blinker to blink a little faster than stock.
60 LED version. This is the bulb you will receive!!
Make sure when you order you select 1
$50 each set
Order here
OK JW, I'm a little confused. Pardon my ignorance. What does 'switchback' mean? Is that the same as the daytime running lights? In the video the light goes back and forth between an amber and a white light. Is that how the DRL will look going down the road or is that just showing the difference between the stock and your LED replacement?
Or is that showing how it looks with the turn signal on?
Thanks, Randy
Also, how hard is is to make the switch?
Thanks, Randy
Banned Scam/Spammer
I'm going to check with my tester for clarification, but on the C5 they are amber with lights off and white when on. They then switch back and forth when signals applied.
On the C6 I know you guys have several light settings so I'm not sure if they work this way or not. I know they switch when the signals applied though.
I'll have to ask about installing also.
Banned Scam/Spammer
I emailed him. I really think it depends on your setting though. I remember reading something about that.
I'll post back up when I find out.
I bought these and there great!
When you turn the car on and put into drive the light will be orange.
I turn the switch back so I have no DRL.
With headlights are on or switch turned down 2 clicks (I think) or with fogs on it will be the hyper white color.
Then when any of the above applicatons are on (hyper white) and turn signal in applied it goes white/amber/white/amber. Very cool and eye catching like nothing else on the road.
Banned Scam/Spammer
I did a search and found out how. It seems easy
http://forums.corvetteforum.com/c6-t...nal-light.html
You have to turn your wheels or remove the wheel depending on preference and if you have nice jack and whatnot. I just turned the wheels then you take out the plastic tacks that hold the black liner on. Then just reach up and undo the light pull stock out and put new one in.
Its not hard to do at all just a bit challanging with bigger hand its a small space to reach through.
Afraid not. I already bought several things from Jhonathan. He's a great vendor. Very happy with his LED lights.
But thanks for your input.
I will post pictures comparing stock to these.
I'm still confused as to how the lights operate. What I would like, is that the DRL's would be white(with or without the headlights being on) 100% of the time. Then only be flashing amber when the turn signal is on. I have a C6. Is this how they operate?
Banned Scam/Spammer
If none of your lights are on they will be amber.
We have all white light leds if you are interested in those. They don't switch though.
