Horn will not turn off. Need some help.
My horn has been blasting constantly and will not stop. I tried the remote but it will not stop. I finally got it to stop and while driving the car the horn came back on. The sound is constant horn, not like the like the panic horn sound. As if someone is holding down the horn button. I had to pull the fuse and took the car to the dealer. The light do not turn on or blink while this happens. You would not know the horn noise is coming from my car unless you were next to it. They took apart my steering wheel and are trying to find a solution.
Has anyone have this happen to them or know the fix? I don't want the dealer disassembling the car to not find a fix. I don't know if water somehow gotten into the car and created this problem. It been raining hard here in california.
When I picked mine up at the dealer, a similar thing happened. At the final detail before delivery, somebody ran a pressure washer across the engine. Water got into the fuse box. Once everything dried out a day later, things were fine. Pull the fuse and blow out as much moisture as possible.
Good luck.
Good luck.
Received 8,928 Likes
Sometimes the steering wheel switch will fail and short out. Not a common problem but dealers should be familiar with solving this type of problem which goes back to when cars first got electric horns with a switch mounted in the steering wheel.
Bill
Bill
Good luck.
Good luck.
What about a horn relay, you can test the power wire to the relay and determine if steering wheel switch is bad; then if not go to other things? Sounds to me dealer does not know how to trouble shoot EASY things, I would hate to see HARD things. I would find another dealer, probably too late now!
I had that happen on my C5. Had it at the dealer twice, but it would happen at random times. Drove around for 2 years without a horn...probably kept me from pissing off a lot of other drivers.
Trial and error!
We use to buy those large horn buttons and mount them on the steering column and run wires from fuse block to the switch, then the horn relay, then if half to, replace wires from relay to horn until works with switch. Yes, sometimes the wire and circuit in the steering column for some reason just quits working. Most of the techs these days are basically "light bulb changers" with todays electronics, they cannot really trouble shoot problems, just substitute parts until something works. Throw away maintenance today because of chips and printed circuit boards.
Well...
Not sure is the fuse box was blown out, or they blew it out with air, and it did not fix it.. but.. it does not sound right. Most people don't know that the horns are hot, and that it is ground that is switched.. so water CAN complete ground... Sounds like a lot of $$$ for a fuse box...that you may not have needed.
Sorry, correction.
Former Vendor
Horn blows
Had this happen a lot if the detailer gets too crazy pressure washing under the hood, also had it happen with a 07 Z charging up the battery using the terminal on the under hood fuse box was raining lightly the following day the daytime running lights wouldn't turn off and the horn wouldn't stop blaring, tried to blow out fuse box, nothing, had to remove fuse box and blow out from the backside and the plugs that bolt into the f-box, put it all back together no more problems....
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
O.K. - a funny story. Some friends of ours have one of those Explorer Tracs (about 7 y.o.). The horn will go off when they least expect it.
If it happens while they are behind someone at a stoplight (or similar), they'll look out the side window, and act like they're waiving to someone.
They say it really sucks when it happens while they're behind a police car.
Good luck.
Good luck.
times before and the horn came on when I came home. I unhooked the
battery till the next day. All was fine!
CI 1-4-5-8-9-10 Vet
The dealer's technician told me not to use a power washer (or car wash) or it would happen again. He said a garden hose would be much less risky, and don't be doing it too often. So about once a year, I'll spray a little simple green on the engine / compartment, and hose it off with a garden hose. It looks plenty clean and no electrical gremlins. :
Convience!
Horn relay on C6 just happens to be located in the engine fuse box. It is easy to get to and is not hidden. Fuse box is not the problem unless fuse is blown or water inside, it just convinent to locate relay there.
... addition,
I used to power wash under the hood of my IROC-Z. I had a couple of similar problems with electrical connections failing (not the horn though). It was a TPI motor, and port fuel injection was new at the time. Fortunately for me, it was still under warranty.
I have even taken corroded (battery leak) electonics (radios, etc.) and gently washed area with light water spray after carefully removing large chunks of corrosion and gently washing out and drying with HIGH blower speed from a hair dryer on LOW heat. Sometimes use a tooth brush to help. Just make sure everything is absolutely dry before reenergizing. I even put small items next to refrigator heat exhaust for a day or two to get ALL moisture out. Any low heat source over time will solve the moisture problem, just make sure to blow out all the moisture very thourghly, blowing won't hurt it, but moisture will.
CI 1-4-5-8-9-10 Vet
thanks C6keller - that makes sense on the fuse box.
Agree on the leaf blower too AND agree on the elecronics. When people get water in an electronic device, they might be tempted to energize it to see if it works - which probably finished it off . As you say, if one will dry it out real good, and wait to energize, often no harm is done.
Your welcome!
