05 Power top won't close all the way - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Corvette General Discussion
General C6 Corvette Discussion not covered in Tech
Old 03-12-2010, 10:17 AM   #1
PR4424
CF Member
PR4424's Avatar
Default 05 Power top won't close all the way
So last night I drove to my hockey game with the top down and when I got there the top wouldn't close completely. It looked like it was going to close, the top would get about 8" from the windshield but then would go back down (as if I was putting the top down) until it was in the up right position.
I tried shutting the car off several times, indexing the windows and putting the top up and down numerous times. I eventually drove to a GM dealer where service was closed (I was hoping I could find a salesman who knows about verts). Well, I showed him what was happening then he went in to ask his manager for help and when we went back outside to show him it worked.
This happened once before but after trying to open and close it once or twice it closed properly.
Has this ever happened to anybody?
PR4424 is offline   Reply With Quote
Old 03-12-2010, 11:43 AM   #2
Justasheet
CF Senior Member
Justasheet's Avatar
Did you get any messages about the partition?
Justasheet is offline   Reply With Quote
Old 03-12-2010, 02:04 PM   #3
PR4424
CF Member
PR4424's Avatar
No, there were no messages except saying the top wasn't secure (not closed).
Any ideas?
Old 03-12-2010, 02:11 PM   #4
cclive
CF Senior Member
cclive's Avatar
I am thinking one of the limit switches...the top doesn't know that it is in that 'almost closed' position.
cclive is offline   Reply With Quote
Old 03-12-2010, 04:38 PM   #5
brimee
CF Senior Member
brimee's Avatar
It sounds like the switch you hold in for the top to go up is bad and shorts the other way for down, dunno, maybe...
If it happens at the same position, 8 inches from the windshield, everytime then one of the other switches, but I thought it only activated them switches when it was all the way one direction or the other.
A quick look at the schematic it appears the only way this could happen is a bad control switch or folding top control module. Getting the top not secure message indicates that the control switch was released, that is the only time that it sends that info to the DIC. I bet you have a flakey switch.
brimee is offline   Reply With Quote
Old 03-18-2010, 11:32 AM   #6
PR4424
CF Member
PR4424's Avatar
So I have put the top up 5-6 times since the night of the problem and it hasn't happened since then. I am starting to doubt myself thinking that maybe I didn't hold the button long enough. Currently, when I close it it closes 80% of the way then opens slightly, pauses for about 2 -3 seconds then the top comes down the remainder of the way to the windshield.
Is the 2-3 second pause normal? If it is, maybe I was just releasing the button right before it started to move? I can't imagine I was doing that abut I was frustrated so maybe it is possible.
Old 03-18-2010, 12:18 PM   #7
IDSRVIT
CF Senior Member
IDSRVIT's Avatar
The pause is normal....mine does it too (from what I remember before I stored it last year at least). This last pause I believe is the hard cover latching. Top won't go the rest of the way until that occurs.
IDSRVIT is online now   Reply With Quote
Old 03-23-2010, 08:58 PM   #8
Curti
CF Senior Member
Curti's Avatar
Default Power top
Did you ever resolve this problem? My car does the same thing, every time. When it gets to the 80% it reverses and starts to lower again.
Maybe it is common to black verts? ( see avatar)
Curti is offline   Reply With Quote
Old 03-23-2010, 09:59 PM   #9
PR4424
CF Member
PR4424's Avatar
No, mine does the same thing. Since this is my first Corvette convertible I am assuming this is normal operation. I haven't had a problem closing it since I started this post. I am thinking I was just being too impatient (hopefully).
Am I wrong in thinking that this is normal?
Old 03-23-2010, 11:36 PM   #10
cclive
CF Senior Member
cclive's Avatar
Old 09-19-2016, 09:04 PM   #11
hamertime
Junior Member
Default top wont go the rest of the way down
If anyone can help. my top wont close either. so the tonneu latch is not closing all the way is what I'm getting how do I fix it?
hamertime is offline   Reply With Quote
Old 09-19-2016, 10:00 PM   #12
Curti
CF Senior Member
Curti's Avatar
Quote:
I just put my elbo on it when it is almost closed. That way you are not messing with the switches and the tonneu still fits nice.
Old 09-19-2016, 10:49 PM   #13
Kenny94945
CF Senior Member
Kenny94945's Avatar
Could be many things...most common the partition switches.
But...the reason I am posting, as a reminder is for many to review their owner's manual for the emergency top up/ down release procedure.
(Loosen a fitting on the hydraulics - pass side upper behind seat).
Good luck wished.
Kenny94945 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 05 Power top won't close all the way
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Senility update jay c smith C6 Corvette General Discussion 11 08-20-2016 09:33 PM
    power convertible top question diitto C6 Corvette General Discussion 102 07-08-2016 02:59 PM
    Power Top not closely completely bheathcoe_07 C6 Tech/Performance 10 03-30-2013 06:14 PM
    2000 vert, toneau cover rubbing when putting town up/down T_Vert C5 Tech 6 09-27-2010 01:03 PM
    What To Do If Car Can't Be Repaired..Need Advice TexasMadMan C6 Corvette General Discussion 22 07-31-2010 01:36 AM
    Tags
    2005, c6, control, corvette, folding, module, power, problem, problems, put, secure, switch, top, tops, unlatch
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
