Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing
- How to Remove Water Spots from Black Paint
Step by step instructions for do-it-yourselfers.
How to remove Water spots from Black paint
Using Z-PC by hand requires quite a bit of physical effort compared to the normal Zaino product line. Z-PC and AIO are the only two products, if used by hand you might/should be working up a sweat, as they require some effort in order to get the mild abrasives to do their work.
At my detailing shop, Z-PC and AIO are the only two Zaino products that are applied using a Porter Cable.
I don't have a porter cable.
Once you claybar a Zainoed car does that mean you have removed everything-all past Zaino coats meaning you are starting over from ground zero?
I bought a used black 2001 Mustang Bullitt from my daughter. It had more water spots than any other car I have ever seen. I tried all sorts of cleaners and polishes for paint, with no luck. What did work, was Meguaires plastic polish.
