Targa Top Noise from rear pins?
Guys, I know the front part of the targa top latches tend to make creaking noises. But do the rear "pins" have a tendency to make noises as well?
The noise I am receiving is like a metal on metal clank when going over a hole, or bump in the road.
Any ideas on how to dampen that?
Dealer is supposed to ride with me tomorrow to pinpoint.
Received 2,225 Likes
I've had a rattle that had gotten worse and worse over the last 6 months. It sounded like it was coming from behind me but when I held my hand on the front passenger latch as I drove the car, I could feel the rattle very clearly. Turned out the pin was loose and that was what was rattling. Tightened up both pins and rattle gone.
Check the tightness of the front pins as well as the rear pins.
Other than lubing the pins and making sure they are tight . I found it really mattered the order you latched and unlatched the top. I was latching the front latches first then the back. Once I reversed that and always latched the rear first , both off and on, the squeaking subsided . I also noted that the rear seal seated far more evenly. Also make sure this has a light lube as well . Hope that adds a new wrinkle.
P.S. I remember an old post about this same problem and one idea was to remove the rear pins and install a thin rubber gasket as an insolator. I have no idea how it worked. Also just an idea but how about "dipping" those pins in a plastic kote liquid or even installing some thin "shrink" tube over the pin as an iisolator.
"Beware Mad Scientist expounding"
