Oil Life Monitor / Battery Disconnect?
Does OLM reset when battery is disconnected? I'm guessing yes, but wanted to confirm.
No, the Oil life monitor does not reset on a battery disconnect. Nor will you loose any radio station presets or memory information. You will need to re-index your windows but other then that, everything should stay the same.
CF Senior Member
What about OBDII memory/monitor information...is that retained in the event of a battery disconnect? I recently took my car in for its first state emissions test immediately after replacing the battery. The state test results were "The OBDII system is "NOT READY" as reported by the vehicle's on-board computer." I was surprised the system simply reported "not ready." I had a code reader on the car the day before and all monitors were reporting 5 x 5.
CF Senior Member
There are some emissions type codes that can be reset with a battery disconnect. As such, a safeguard is built in to the system to prevent people from fooling inspectors by pulling the battery prior to a state inspection. Depending upon the test there are X number of cycles of operation required prior to the test being conducted. The information isn't gone per se but the test protocols prohibit the test being done without the appropriate time, ignition cycles and or miles on the clock.
My car doesn't throw any DTC's but I wasn't necessarily expecting to pass the inspection anyway (with non OEM cats, etc.). At this point, I'll get some more drive cycles on the car, check the OBDII with my code reader and maybe next week I'll take it back through inspection to see what happens. Should it fail I doubt I'll put the stock manifold, exhaust, 02 sensors, etc. back on just to pass the inspection. My car's been slowly evolving into a dedicated track car so this may be the defining moment. I won't be disappointed if it fails. Then I can stop making certain compromises and finish setting it up properly for track use. Thanks again...I appreciate your time and expertise!
Thanks Paul. I just didn't think about what effect replacing the battery might have on the OBDII until after the inspection. My battery died right before I left (which irritated me) and then when I pulled the battery I found an Optima. I was blown-away as I've never bought an Optima battery. I'm guessing a performance shop in Phoenix recently mixed-up my 1 year old conventional battery with someone else's Optima. In any event, I went to AutoZone and bought a new replacement battery, fired it up and drove to the inspection station.
Received 2,046 Likes
St. Jude Donor '13
On our 2006, resetting the "Elapsed Time" timer in the DIC would also reset the OLI.
You should have seen the tech's face when I showed him that "feature".
I'm told that newer years don't do that, and there may even have been a fix for the 2006's.
Thanks guys. Reason I ask is I'm looking at buying an '05 and noted 25% on the monitor. It could be worse than that if the system resets after a battery problem or whatever. Good to know the car keeps most everything during a battery swap. The C4's were not like that.
I had my battery disconnected for six months this winter and the only item that needed resetting when i hooked the battery back up was the window indexing.
To get back on topic since I normally only drive my car on weekends I disconnect the battery when not in use. I lose the window index, clock, and all of the emission tests.
