Question about tintcoat
How many coats of tintcoat are used on the cars that have it from the factory? I thought it is one coat applied after the clearcoat but can't remember.
From what I was able to find out online I guess the steps are paint, then the tintcoat, and then the clearcoat. According to my body shop guy my paint code, U512Q(I have jetstream blue metallic tintcoat) only brings up bluestream paint. No further info relating to the tintcoat. A guy who does painting that did some fuel rail covers for a jsb car mentions this in his thread on streetcarsusa.org
"the color is a special order color. takes about a week to get it in and cost me $85/pint. thats just the color. not the reducer for it, or the clear coat that goes on top. it has a special flop pigment in it. the color flops from blue to teal."
Thread is : http://www.streetcarsusa.org/forums/...read.php?t=652
Apparently he is calling the tintcoat a reducer. Regardless, my body shop guy thinks he did the painting of the extra rear valence I got correctly but I knew when I saw it that it looked too light, hard to tell right away but looking closely holding it next to my car I could tell. He told me to call the GM dealership nearby and verify if it is a three stage paint, so I guess I will call tomorrow and verify that it is.
Updated my original post. This pisses me off because a paint supplier is giving incorrect information for cars with jetstream blue metallic tintcoat, leaving body shop guys to assume they can paint and clearcoat and then done.
A little Tricoat info http://www.cyclecolor.com/id38.htm
Holler Cheverlot removed and sprayed my 08's JSB nose to remove chips right before my purchase. The shop had to redo it once to get the color right. I believe the body shop manager said 3 coats of different products were used for JSB tincoat process. Tony Johnson in sales may verify this process for you or transfer you to the body and paint manager: 888 SHOP CHEVY
I bought in JAN. Holler did a very commendable job, matching the car perfectly.
I remember this topic came up in the past and there were conflicting answers.
1. Base coat (color)
2. Tint coat - a more transparent coat to bring depth in the metallics.
3. Clear coat
VS
1. Base coat
2. Tint coat - a more transparent base coat.
Interesting enough my Crystal red touch up kit comes in two bottles.
1. Base coat
2. Top coat - a more transparent base coat.
I am still confused
3. Clear coat
VS
1. Base coat
1. Base coat
I am still confused
3. Clear coat
VS
1. Base coat
1. Base coat
I am still confused
3. Clear coat
VS
1. Base coat
1. Base coat
I am still confused
Am I right in asking my body guy to repaint for just cost of the paint once I get a dealer confirmation on 3 stage painting?
Every Corvette that is painted in Bowling Green goes through essentially the same paint process which is comprised of a primer coat, a base (color) coat and a clear coat. Where the "tint coat" colors differ is that a tint (pigment) is added to the clear coat stage to change the final color of the car from what it would be with a conventional clear. Crystal Red Metallic and Jetstream Blue metallic are two of the colors over the model years that have a tint coat in place of a conventional clear coat. These are not tri-stage paints but simply base coat / clear coat paints with a bit of tinting added to the clear.
The reason for the additional charge for metallic tint coat colors is as much due to material costs as it is due to labor costs. The tint coats are painted by a clear coat robot that has to be drained down and cleaned to switch between conventional clear coat and tinted clear coat.
We need to be careful when comparing the OEM paint process and materials to those of the aftermarket. The paint the plant uses is a wet on wet process with an oven cure. This simply can't be done effectively on the outside and as such, different manufacturers have different approaches to achieve the desired results and match.
Since it can't be repainted at the factory (which would be great) it's still an "iffy" proposition to a large degree. .
It's really a crazy situation because the rear valence looks like if you would lay some 50% tint over it there would be a 99% match to my jsb's factory paint.
So, is the oem process a two coat process and the aftermarket a three coat process? Or does it depend on the aftermarket bodyshop which method they choose to use?
I think if you paid him, in total, the amount the other shop was going to do it for, it would be more than fair for him, and you still won't have overpaid. I know many here will tell you he should have known and make him get it right for the price he quoted, but I'm speaking as an ex-tradesman and current estimator. People make mistakes. Flame suit on.
The "tint coat" is what used to be called "candy".It is sprayed to achieve the desired effect or in your case a color match.It is translucent and applied over the base.A letdown panel is sprayed with one or more coats of candy to find the amount of coats to be used for the best color match for your car.Then clear applied.
From what I have learned it is the other way around in general, oem is three stage and most aftermarket two. As I found here in Bloomington the dealership and two independents quote it as just a two stage, whereas one independent shop quoted it as three. As I found out, without blending to adjacent panels it seems two stage is harder to achieve a good match. Slogo is right in what he said since the paint guy at the GM dealership even mentioned it being a candy paint.
Holler removed the the gas cap with the front bumper to help match the color. They had it nearly reassembled when I arrived to buy it.
Watching the car reassembly in the body shop, I asked if any any additional paint might be remaining to take with the car. The shop manager said he had two of the three products remaining in cans, but, I would need to later purchase more of the third.
It may have been all three - primer, paint and clear tincoat. He said something about a special process to get the color right. Paperwork took some additional time. A long storm during rush hour through the dark was attending to my better interests to safely be homebound.
I later thought fresh product matches for paint coverings may be best. The time-related storage considerations and finding a talented applicator agreeing to use the products started bouncing off my radar. Later, I wish I had it for a GM C6 Vert 1/12 model. Now, I'm thankful that project never left the drawing board. Factory silver is good for good.
Location: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
Is there a Dupont rep on the forum that I can talk to about how jsb should be paonted aftermarket? The body shop gave me a car back that looks like a patchwork quilt.
