Disconnect Intake Bellows PCV Hose?
Received 2,045 Likes
St. Jude Donor '13
My 2009 Coupe has a small hose (PCV?) that goes vertically into the intake bellows. It looks like removing this hose would make it easier to move things around when replacing the air filter.
The hose has what looks like a quick release fitting, there is a springy tab that can be pushed/rotated. But the fitting still dosen't want to come off, do I need something else to release it or just hold the tab back and pull up harder?
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
big sharp scissors will do, Jim.....j/k.
St. Jude Donor '13
St. Jude Donor '13
Nobody???!!!
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
On my '07 it is just a barbed fitting that goes into the coupler. Just twist a bit on it while pulling.
Like you I got frustrated with getting that dam hose off and than got a pair of long needle nose pliers and went in directly from the top and success - such success that it took like 2 seconds - very easy I guess with right tool. Place the need nose around the "press release" squeeze and work back.
