Weird Clutch Noise with A/C ON? help?
I tried searching but couldnt find anything. When I turn the A/C on, i get this weird noise (a "vwheeeeh") and sensation through the clutch when I go to shift. It also happens when I slow down in gear. I have no idea what it could be. When I shut the A/C off, everything is fine. Any ideas?
Sounds exactly like what I am experiencing recently. I was thinking it's the throw-out bearing going bad, which is strange since I had a new slave cylinder put in about 5 months ago with the new clutch.
It happens randomly so I can't really duplicate it to show anyone, but I did notice it seems to happen more when A/C is on.
I just can't imagine how the whine noise/scraping sensation in the clutch be related to the A/C...
Me too
My 2007 does it. With the A/C on it hums/vibrates as the rpms come down during clutch engagement. Turn the A/C off and it completely goes away. It is either the compressor or one of the idler pulleys, but I haven't yet sorted out what it is. Mine has been doing it since about 30k miles. I have 48k on it now.
Clutch whine and odd pedal feel in hot weather with A/C
-2006 Manual Coupe
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
I've read some posts on here an it all points to the AC compressor going bad. When changed out the noise goes away. My does te same on my 08 Z. AC off an it's fine.
CI 7-8 Veteran
St. Jude Donor '07
No reason to change it unless ur coming up on ur warranty. When I get around to it I'll have that changed along with the o-ring in the dry sump system being torn an which causes a rattle at RPMs
Mine is also doing it... Go start the car, turn the a/c on, wait for the car to warm up, rev it to about 2500-3000, and let it fall. My car does it every time! I live in Orlando, and it's the hottest time of the year by the way!
There is a guy who made a video and put it on here. I don't know about you guys, but mine sounds identical!
http://forums.corvetteforum.com/c6-z...hts-video.html
It is also referred to here as well…
http://forums.corvetteforum.com/c6-z...o-bearing.html
My car is an 05, and has 53,000 miles on it, so the warranty is long gone. I put a can of PAG 150 in there today, so I’ll update and let you know if that does any good…
Received 8,927 Likes
I hear a noise like that when I let the clutch out after shifting. Hard to hear it over the tire, exhaust and A/C blower noise but it definitely does it about half the time I make the 1 to 2 shift.
Bill
Bill
hey guys, if your car is making this sound, can you go to this thread and post a reply? I am going to try and convince chevrolet that this is an issue that several people are experiencing, and that it is something they should maybe consider putting on a recall list or something...
http://forums.corvetteforum.com/c6-c...ine-video.html
Will work for HPDE time.
Thanks,
Laura
GM Customer Service
The noise reminds of the old days when we had mechanical clutch linkages that went through the floor/firewall and had rubber seals around them. If the seals dried out you would get that noise and a couple of shots of lubricant would stop the noise.
Bill
