ATD 7325 Jack "white tubes"
I bought the ATD 7325 hydraulic jack and it came with two thin wall hollow metal tubes. Each tube is 1.12" in dia. and 15.5" long, painted white and one end on each tube is closed off with with a (approx) 1/4" tapped hole in it.
I can't figire out what these tubes are for.
Anyone else that has bought this jack know what these tubes are for?
(It' the same jack as the Omega version or Blackhawk version from Northern Tool)
I have this jack and mine did not come with the white tubes you described. I have an older version that is red with a black handle, I think the new one is blue, I am not sure what color the handle is. What you describe almost sounds like the handle part, except each piece of mine is about 24" long an about 1-3/8" and they have tapped holes on one end of each to bolt together to form the long handle (that won't pull apart). Your pieces are smaller than mine, so if it is not the handle part, I have no idea what it is.
