Buzzing in the dash
Buzzing in the dash
When I start the car up in the mornings I notice a loud buzzing coming from the dash. It sounds like it is coming from right behind the gauge cluster. Is it the HUD? Anything to worry about? I does seem to go away after I have driven it a bit or when I turn the radio up
It could be your ambient Temperature sensor. Right next to your start button.
There is a little fan in there that sucks air through thesensor than can go bad.
Mine was buzzing and I had it replaced and it is quiet again.
Also the flexible cowl cover covering the bottom of front window ( outside ) can vibrate but this is under speed or with a strong head wind. This sound is heaver sounding than the temp. fan buzz. Light buzz then probably the temp. fan as stated above.
Is there a fix for the cowl cover vibration? My car gets the intermitent dash rumble noise when it is at highway speed and the ambient temperature is about the same as in the car or on a highway with a textured surface. Of course, the dealer service department can never replicate it.
Is there a service bulletin on this buzz that seems to come from the dash in front of the passenger seat? My new (leftover 2009 bought in January) Corvette is going in to the dealer for its first service. I have asked them to look into the problem with the buzz in the dash, but it is an intermitent problem that doesn't occur ofter. When it does, it will drive you nuts because it is so loud. Rougher blacktop surface seems to cause it.
I also have some sorta type of buzzing sound on passenger side around dash. Although I believe mine has to do with glove box, it's intermittent and when it occurs I open the glove box and close it a few times. I need to lube the latch on it, not sure if there is any adjustment for it.
