Non-runflat tires on run-flat rims?
Okay I've read that you're not supposed to change run flat tires to non run flat tires and keep the same rim. Something about the rim being designed specifically for run flat use only and could be damaged if used with non run flat tires. But with the C6, is it okay to use the stock rim with non run flat tires?
Not a problem at all, literally thousands of C5/C6 owners have changed to non run flats on stock rims with zero issues.
I know the Honda Odyssey has unique rims, but the Vette is not an issue at all.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
I dunno, ask honda odyssey.
otherwise, edPA is correct for our C6s and most cars.
Location: Stafford VA, home of our wolf den. No house break ins to date.
nah uh.. if anything, the rim is beefier to support the load of the vehicle with the flat tire now that the air is gone from the tires chamber, which supports the load normally.
Salty Veteran
Mike
Here is a website articles stating you can't use non run flat tires on run flat rims:
http://www.ehow.com/i/#article_5222044 (it mentions under 'Step 2')
And, the system will be a pain just like the TRX system was a couple of decades ago. You will forever be limited to the few PAX system tires available. Bad idea....
Read all the posts on this and have a question. Has anyone experienced a sudden flat of a non-run flat tire? Did you have any damage to the rim and how did you deal with the situation assuming that you didn't have a repair kit/pump/etc?
I ask because our 05 has non-run flats that are nearly new - I'll replace them with run flats when the time comes.
TIA
TIA
Retired & lovin' it!
Received 8,917 Likes
TIA
TIA
The guy I sold my 03Z to got a flat tire on the right rear of the car after crossing a railroad track. He tired to drive a couple hundred feet to a safe place along side the road and ruined the tire. The rim cut the inside of the tire sidewall but the rim itself wasn't damaged.
Bill
1. that salesperson sold a few million cars.
or
2. that salesperson alienated a bunch of customers with his/her lies.
