2011 Grandsport 'vert - 16 days of ownership = 3 problems
I bought my '11 GrandSport convertible on December 6th from Boardwalk Chevy. The purchase experience was great, Tim was awesome, picked me up from the train station, hooked me up with a few discounts and the final price was great. Really smooth transaction.
and then it kind of well down hill.... As we drove to the gas station for my free fill up, we noticed chatter and a bit of a shudder at low speed turns of more than 45 degrees. We chalked it up to brand new sticky Gen2 tires and slightly wet ground. We got back to the dealership and went through the standard walk through of the car before I headed home.
Just before driving home, the tire pressure sensor for the front right wheel dropped to 0 and the service tire pressure warning came on. I had Tim check the tire pressure with a gauge and it read fine. No biggie, we figured the sensor needed to be replaced or recalibrate. It was late and I needed to get home, so off I went.
For the next two weeks the chatter / shuddering continues whenever making tight turns. It's really bad pulling into parking spaces and into my garage. After 700 miles, the tires should have broken in and it definitely doesn't feel right, differential? I had planned on bringing it in to the dealer next week.
Well, as luck would have it, Wednesday I'm on my way to the mall to do last minute Christmas shopping and right after I fire up the car I get a new warning in the DIC. Service Ride Control - Speed Limited to 158mph. (it has the F55 option)
I call up Boardwalk Chevy, and they said they can get me in the next day. So I drop off the car yesterday, they gave me rental right away.
A few hours later, they called said they recalibrated the TPS sensor, and said that the ECS module was faulty causing the ride control error message. They ordered the ECS module which will take a week to get. The shuddering while turning issue they wanted to have another manager look at it the next day.
Well I just go the call from the dealer, the chatter / shuddering is considered NORMAL due to the wide sticky Gen2 tires. I don't know if I buy that.. I'd like to compare my issue to another GrandSport and see if it is indeed normal.
Anyhow, just had to vent.
Just check here on the forum and you will find many inquires about this.
This is because of the width of the tires, the stickiness, and the turning radius. Just physics.
I have the Z-51 2009 c6 and my dad has the 2009 base c6. They both have a "shuttering" only at speeds under 10mph and the wheel turned all of the way one way or the other. If it is something more than that You may have a problem.
Sorry to hear about your other problems. Only problem I had was when my airbag sensor light came on when i was engaged in spirited driving.
Is it possible for you to do a test drive with a new GS with the GEN1 tires so you have a reference point? MY 09 Z06 has the GEN1 tires and it dosen't have the problem, that I have noticed. I never noticed that problem with my C5 on GY RF's or when I replaced them with Michelin A/S ZP's. I had a 1983 Z28 back in 1983 and it had the shutter, etc on tight turns with the Goodyear tires(215/65-15). At less then 100 miles I replaced the tires with a higher perfomance GY tire(230/60-15) and it helped some, but didn't get rid of it completely. I could change the alignment and switch the shutter from one front wheel to the other, so I assumed it was in the design of the front suspension and steering on the Z28.
Someone else on this forum was complaining of this problem also with their GEN2 tires. I'm wondering if it has something to do with the thread design.
Remember guys. The HIGHER the PERFORMANCE, the more quips and quirts you will have. Just called paying the performance physics guru. Congrats on the new ride.
My old 2005 vert had the shutter with the goodyears and the Kumho non run flats that I had on it. My new 2010 GS coupe has the shutter as well. It may even be a bit worse since the tires are even bigger than my vert.
Tire chatter is NORMAL and been part of the Corvette experience for a very long time.
The other issues are bugs that can be solved and should pose no long term driveability issues once fixed.
Tom
Tom
My 2008 base (Z51) chatters if I crank the wheel while turning
No way around the fact that it plain old sucks when you buy a new dream car and have problems from day 1. Hopefully the rest of your time with your awesome Vette will be more joy than rant.
When sweeping through a long curve at 95 mph you will feel the tires stick like glue and the G forces pulliing on you. There will be no chatter but you will have a large smile on your face. I know this to be true. Enjoy
I'm betting the build date was a Friday afternoon right before a holiday weekend. (What you're describing is not "normal". 3500 miles on my GS and no issues.)
I noticed the same thing...It happens when I go slow and make a turn...Such as parking. I realized it was just the way the car rode with these big tires and huge turn radius. Your good.
Props to boardwalk chevy for great service!!!! My chevy dealer wouldn't even answer the if that happened to me lol.
The Consigliere
Received 5,424 Likes
Don't let it get you down.
Sucks you had a couple early issues, which most don't, but it'll all get sorted out.
I have the same problem with the wide GS tires - it's even more pronounced on a rough macadam. Like when I'm turning in my street after pulling out of the garage.
