C6 Headlight lense replacement help?
Old 01-08-2011, 11:11 PM
Harry's 81 C3
Harry's 81 C3's Avatar
Default C6 Headlight lense replacement help?
I need to replace my front headlight lenses. Is that something for the dealer? Where can the lenses be purchased? Degree of difficulty? What all must you remove to replace? Or do you purchase the entire light assembly?
Old 01-09-2011, 12:14 AM
Darrelk
Darrelk's Avatar
Default !
Not sure about the dealer doing the work but it can be a DIY project. Contact RL Sebring on this forum for slightly used lenses. Couple hundred bucks or so for a pair if I remember right. Only downside is the front nose has to come apart to take out the entire headlight bucket. I took my lenses out with heat gun and elbow grease. Entire project took me around 8 hours. Well worth it though. Have you checked out prices on replacement headlights as a unit? Yikes!
Old 01-09-2011, 02:15 AM
spongjim
spongjim's Avatar
Yes the complete nose has to be removed . It is alot quicker if you have a rack to work on. The dealership will most likely charge you 3 to 3.5 hours .Thats what we charge. Black vettes are usually 3.5 because of the care that you have to take to prevent any scratches. If you decide to do it yourself just take you time and also ask the dealership to print out the directions for you it shouldnt be a problem if you are a customer of theirs. If they wont feel free to email me and I will get them for you.
Old 01-09-2011, 04:32 AM
1bamfv
1bamfv's Avatar
If you don't feel its a job that you can DIY check out this thread. Its a vendor on here that you can send them in and have them replace the lens.
http://forums.corvetteforum.com/c6-c...t-service.html
Old 01-09-2011, 08:39 AM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old 01-09-2011, 12:29 PM
CSixDude
CSixDude's Avatar
I bought a lens from East Coast Performance after one of mine cracked and replaced it myself at home. It was quite a bit of work, but I managed to get it done. You have to remove the entire headlamp assy from the car and then bake it in the oven to soften the glue so you can pry the old lens off. Then you have to clean out all the old glue from the glue channel and glue the new lens on and let it sit a day to cure.
On a 1-10 degree of difficulty scale, I would probably give it a 6 or a 7. Getting the headlight in and out of the car also takes some work cause you have to take the front fender and fasica loose.
You can also take it out of the car and mail it into East Coast Performance and they will swap out the lens for you if you don't want to risk doing it yourself.
A new headlight assy will run you around $950 or so. I think I spent about $175 for just the lens. The savings made it more than worth my time and trouble.
Old 01-09-2011, 01:37 PM
cclive
cclive's Avatar
The dealer will just replace the whole assembly. They will not go through the lense replacement procedure as it is not a GM procedure.
Old 01-09-2011, 06:19 PM
str8jakit
str8jakit's Avatar
135.00 on ebay.each lens
Old 01-09-2011, 10:43 PM
Buster1
Buster1's Avatar
It's the whole assemble I thought. I've seen them for a lot of $$ new.
Old 01-10-2011, 10:46 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
There's actually a hand full of dealers buying the lens and changing them out. I personally think they'd be money ahead selling the assembly but who am I to complain?
Old 01-11-2011, 06:31 PM
355Spider
355Spider's Avatar
What temp did you bake it at? I did this on my FJ cruiser but I forgot what temp I did it at. I think it was like 175.
Old 02-14-2011, 12:26 PM
Thudux
Thudux's Avatar
Anyone have instructions on how to remove lenses?
Old 04-23-2011, 08:48 PM
jmt1669
jmt1669's Avatar
St. Jude Donor '11
Can some on PM me with help or instructions? Please
Old 03-04-2012, 11:57 AM
Jhaintz1980
Jhaintz1980's Avatar
I am interested in getting the DIY instructions also please. Thank You
Old 03-04-2012, 12:09 PM
The_Tibulator
The_Tibulator's Avatar
Definitely can be a DIY. Lot of work. Had a couple of friends help me and it took two days to do it.
The vendors that sell the replacement lenses include instructions, which is part of the price you pay when you buy them, so that's why people don't just post up the PDF. They paid for those.
Made a huge difference in look though, so it was well worth it.
Old 03-06-2012, 10:13 AM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
I sell the instructions for 25.00 credited back to your purchase.
Paypal is RLSEBRING@***.NET
Old 05-23-2012, 08:41 AM
Clement
4th Gear
Clement's Avatar
Default changing lenses
Hi every one,
can somebody tel me what quind of glue we have to use to fix the lenses on the core?
Clement
To C6 Headlight lense replacement help?
Old 05-23-2012, 10:18 AM
The_Tibulator
Originally Posted by Clement
Hi every one,
Clement
Old 05-23-2012, 10:39 AM
JIMSC62006
JIMSC62006's Avatar
If you decide to replace with a complete light be prepared to spend $995 for each one. I just had one replaced from an accident so I was very surprised at the cost. Also, that doesn't include installation.
Old 05-23-2012, 10:53 AM
Clement
4th Gear
Clement's Avatar
Clement
Quick Reply: C6 Headlight lense replacement help?
