Battery cable clamp nut
Cruising
Folks,
Could someone steer me in the right direction to get one of those special nuts with the cones on the bottom?
I lost mine somewhere under the battery when installing a charger lead.
I know that a 'regular' nut will not adequately tighten the battery clamp, it must be tapered.
Thanks,
Jim
2005 Roadster, Z51, MZ6
Thanks,
Jim
Bad news: The nut is not available as a separate item.
That is, every time I've investigated, you can only get the nut if you buy the entire clamp/cable assembly... about $200.
Definitely take the time to search for your missing nut.
Some alternative suggestions in a similar thread:
http://forums.corvetteforum.com/c6-c...t-inquiry.html
Not trying to rub salt in the wound, but you only need to loosen the nut (not remove it) to loosen & remove the clamp.
Folks,
Thanks,
Jim
Thanks,
Jim
BJK
BJK
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Get rid of the OEM clamps. Replace them with universal connectors.
http://www.ls2.com/forums/showthread.php?t=846931
Elmer
Elmer
The magnetic field of magnets has been known to mess up electronic devices (computers and the like). I guess it is possible that the ECM module is not affected by magnets. Depends on how it is constructed.
That part of the car just sucks anything you drop into it -- had to dig a small 10 mm wrench out that tried to escape when attaching my Ctech. Maybe the ECU is magnetic
Elmer
Elmer
BJK
Elmer
It took 15 minutes. Hardest part was getting the initial "crush" of the thick wire to fit the supplied bolts. Once I got it to mash down a little, the supplied bolts worked just fine. $6 for both ends and the cables are plenty long enough. I did make sure to cut the wire off as close to the OEM clamps as possible to keep as much wire as you can for the install.
Elmer
Elmer
Where did you pick up the parts?
BJK
Tossed the boots.
Bought a set of the felt "rings" that fit around the terminals to fight corrosion.
I believe I got the clamps at Advanced Auto Parts for $2.99
You've actually got a few lower cost option's availible. Best would be to get the lost nut back, but surely you've already tried that. Maybe pick up a standard nut, and sort through the hardware store's fitting bin looking for some sort of tapered add on piece. Also, since most later model GM car's use the same kind of cable clamp assembly, maybe just buy a used cable at the local bone yard from a wrecked Malibu or something. Might just be for the nut, but probably cheaper than spending lot's of time on it.
Anyway, you do NOT want to be tempted to use a standard nut with the OEM clamp... more easily corroded and then difficult-to-diagnose problems:
(link has lots of pictures, so it might load slowly).
Above link is also a good heads-up for anyone replacing their battery.
