painted calipers, where do i get new caliper decals?
What some of you are missing is that the C6 Grand Sport shares the same calipers as the Z06 which does not have raised lettering. The caliper surface is smooth with painted CORVETTE lettering on the stock units.
I installed "chrome" CORVETTE decals on my painted 2010 GS calipers and they have held up just fine to heat and the elements. Just make sure the caliper surface is clean before you apply them. I got these from fourthcircledesigns.com.
Hard to see behind my ZR1 style wheels but here are a couple of photos.
Just regular high heat paint as far as I know. My auto body guy, Burke Corvettes in Orlando, did the work. They removed the calipers and thoroughly cleaned them prior to painting. That's the secret. I was originally going to have the calipers powdercoated, but they were already doing some paint work for me so this was simpler at the time.
You don't need a special high temperature heat paint unless your going to track the car. Under normal driving conditions your calipers won't get hot enough to bother even cheap Walmart paint. I know this because I painted mine with Walmart rattle can paint about 3 years ago and they still look good as new.
#35
#36
Are the calipers easy to remove? Do u have to remove anything where u need to bleed brakes when finished ?
Anyone have a link to caliper decals for Grand sport. Can't seem to find decals
#38
Try Fourth Circle Designs, they are GM Licensed to make and sell the brake caliper decals. There web site is www.fourthcircledesigns.com . They make all kinds of decals.
#39
#40
