Drive Thru Car Wash, your thoughts?
I'm pretty sure I have an idea how most of your opinions are going to go, but I'm going to ask the question anyway. I realize that some of us are more particular and passionate about their vettes then others. Some of us drive them on a daily basis though and don't have the luxury of a second car. I for example fall under that category and also live in an apartment complex where their is no place to wash your car. It sucks because like many of you I take pride and actually enjoy washing my Corvette.
With that said, outside of paying someone to hand wash it, or going to a friends who has a hose where I can wash it myself, what are your thoughts on the "drive thru" car washes? I'm not talking about the no touch cheap one's at the gas station. I'm referring to the Car Wash companies. I actually emailed the one close to me as I've used them several times before when I had an SUV, or to wash my girlfriends SUV. Below was his response to my concerns about the tunnel and ground clearance. He said he washes Corvettes ALL the time. I actually kind of believe him because like I said I've seen some pretty nice cars there.
"Yes all of the washes and details you see go thru the car wash first, the car wash is a 100 foot state of the art computer controlled tunnel with the latest in car wash equipment and chemicals and is very safe, we wash everything from Rolls Royce to Ford Tauruses in there and wash about 220,000 cars annually between the 3 washes. "
I have seen some pretty nice cars while here before. I'm curioius what the opinion is of my fellow Corvette brothers and these Car Wash Businesses? Do any of you wash your car through them? Do you think it will harm the car? If I keep enough wax and sealent on it, will it be ok to run through every now and then?
I just bought the car 2 weeks ago, so it was professionally detailed at the dealership. It looked brand new when I picked it up. I'm sure it has several coats of wax on it at the moment. It's black if that makes any difference.
Thanks in advance, I look forward to reading everyone's opinion on the topic.
I say on black go for it. The less you physically touch the paint on black the better. Just keep enough wax on there annually to keep it protected.
That said, I've never been thru a car wash in my life with any car of mine.
I'd never run the C6 thru any car wash.
The brushes or "cloth" they use tend to leave marks. You do not know what kind of car wash liquid they use. Rims get scratched.
Look for a self car wash where you can do it yourself, bring your own supplies, and buy the water with a fistful of quarters.
paulrichy (04-16-2017)
I'd worry more about the tires in the tracks then the paint. I was told by the owner of a car wash that some tires are to wide to go through.
I used to go to my local car wash first thing in the morning when few other people were there and hand wash my car. I would bring my own bucket, soap, and wash mitt then only use their pressure washer.
a lot of automatic car washes use a mild acid to clean the car and this will attack the material in your composite springs. if you don't believe me have your dealer pull up the warning on his GM website. it has caused the springs to fail.
#PIC5335: Composite Transverse Spring Damage - (Mar 4, 2010)
Subject:Composite Transverse Spring Damage
Models:1997-2011 Chevrolet Corvette
2004-2009 Cadillac XLR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="#ss1-2411840">Condition/Concern:
Front and or rear composite springs cracked and or broken on the same vehicle with no "obvious" reason for the repeat occurrence.
<A href="#ss2-2411840">Recommendation/Instructions:
It is important that the Transverse Spring Replacement Procedure is being closely followed and the related special tools: J33432-A & J42188 are being used. Refer to the appropriate Service Information document(s) to confirm the correct service procedure(s) are being followed when servicing this spring.
If the damage is not installation induced, chemical corrosion could be the cause. Engineering has found that two chemicals, Phosphoric acid and Hydrofluoric acid, are attacking the fiberglass/composite spring material. The acids are often found in engine compartment cleaners, wheel cleaners, and underbody cleaners. They are also used by many Touchless Car Washes as part of a buffered cleaning solution. If the concentration is not correct, vehicle damage can result.
Corvette Owners Manuals contain information such as "NOTICE: If you use acidic or corrosive cleaning products, engine degreasers or aluminum cleaning agents on fiberglass springs, you may damage the springs."
Bulletin 00-08-48-005 addresses the harmful effects of Hydrofluoric Acid as it relates to vehicle glass & how to determine if a vehicle has suffered excessive / repeated exposure. Such exposure can also have a negative effect on the fiberglass springs.
This info is to supply the dealer with information to be used by the dealer to counsel the customer.
This IS NOT to make any recommendation on whether or not to replace a spring under warranty or goodwill. The GM Fixed Operation Manager should be consulted by the dealer with regard to this area.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
That would be my recommendation in your situation. In the old days we called them "quarter car washes" because it took a quarter for 5 minutes of fairly high pressure water. Now I think it's probably a dollar and a quarter. Take your own bucket, wheel and tire brushes, towels, etc. and do it like you would do it at home.
C6 wash
Also, what do you use when you "strip and 3 step detail every 6 months?" I guess I mean what do you strip it with and just exactly what is a 3 step detail entail?
Thanks in advance for your help.
Lifetime NCM Member #2482
1 Post
St. Jude Donor '11
I am very particular about my car. However, when the situation is drastic and I need a quick wash I only go to a self car wash to get the worst off. AND, rather than stay there and dry (if I don't have MF towels), I head to the nearest freeway to blow the water off.
You don't have the luxury of at home detailing so I would take my tools with me and find a good self wash. I've never even thought about going through one of those conveyor belt washes with the vette. I didn't think that would be a good thing.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
No!
Elmer
Elmer
A true touchless will work fine.
No "conveyor belt" but a drive thru on flat concrete with no touch spray arms that travel over and around the car. At many gas stations, $5.00 usual with 8 or more gallons of gas for a good wash and blow dry. Take towels to get the last of the water off the body and the glass and to touch up the wheels. It's a great fast wash.
