275 or 295 front tire with a 345 rear tire?
Old 02-08-2011, 12:05 PM
PolishDude
PolishDude's Avatar
Default 275 or 295 front tire with a 345 rear tire?
About to order new tires, nitto invo, going to order sometime today. I have the rear z06 quarter panels and have invo 345/30zr19 tires in the rear, my fronts need replacing, should I go with 275/35zr18 or 295/35zr18 nitto invo tires for the front? I will be running oem z06 wheels and already have z06 fenders and bumper in my living room. My front tires are downright dangerous right now so want to order soon. I was thinking since the rears are 20mm bigger then stock, maybe its better the fronts are 20mm bigger then stock sizing?
Old 02-08-2011, 12:21 PM
QUAKEJAKE
QUAKEJAKE's Avatar
To keep it simple,You don't have to go with the 295's. For the street I'd stay with the 275's.The widebodies have enough issues with sandblasted bodies with OEM tire sizes.
Old 02-08-2011, 12:39 PM
PolishDude
PolishDude's Avatar
I wont get any active handling issues since the rear is 20mm bigger then stock size yet the front is a stock size? Right now I run a 255/40 with normal front, so the sidewall height is almost the same as a 295 345 setup
Old 02-08-2011, 12:56 PM
1 slow 97
1 slow 97's Avatar
run the 275, it will work with the 345 rear no problem. Check out the Z section, lots of guys running that same combo on their stock Z06 wheels.
Old 02-08-2011, 01:12 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
285 will work too, I had 295 on at one point, it's a fat tire. Stick with 275 or 285 with the rear 345.
David
Old 02-08-2011, 02:19 PM
PolishDude
PolishDude's Avatar
thanks! I wanted a 285 but wanted matching tires and invo comes in either 275 or 295
Old 02-08-2011, 02:37 PM
Raazor
Goon Squad King of Battle
Support Corvetteforum!
Raazor's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
i went 275's. no idea why. just did.
Old 02-08-2011, 03:09 PM
SlickShoes
_Sloth Whisperer_
SlickShoes's Avatar
Active handling issues wouldn't present themselves unless the disparity was in overall tire diameter, not necessarily width. Going wider or narrower front to back, as long as maintaining an overall front-to-rear diameter ratio within a few percent of stock, won't be noticed by the car's sensors. That said, just go tried-and-true and stay 275. I don't see any tangible advantage to going to a 295, really. The extra weight will merely affect steering feel when cornering and stress front end components that much more, little as it may be. I ran a 295 up front for awhile under my stock non-z fenders, and clearance notwithstanding, just the heft up front really seemed to tax the steering. And that was with super light 18x11 CCW classics.
Old 02-08-2011, 03:26 PM
NORTY
NORTY's Avatar
Depends on what you want to do with the car.
If, for roadcourse work, then you'll want 295's as the C6 is way under tired up front.
If, for drag racing, neither as a skinny would be best.
If, for just cruising around, then a 275 set will be fine.
Old 02-08-2011, 03:42 PM
SlickShoes
_Sloth Whisperer_
SlickShoes's Avatar
Hardly. If roadcourse work is what he was intending to do, he wouldn't be buying Nitto Invos. On the track, what compound/hardness you select will be exponentially more important than merely 20 millimeters of street tire. Some of the fastest SCCA guys out there are running on 275's.
Old 02-08-2011, 03:53 PM
keyplyr
keyplyr's Avatar
My tires are Toyo Proxes TR1:
285/30-19
305/30-20
DD with occasional Xing.
Old 02-08-2011, 04:05 PM
PolishDude
PolishDude's Avatar
Thats exactly my reasoning for thinking about the 295 because the stock tire is a 325/30zr19...I run a 345/30zr19 in the back. So the rear sidewall is taller then stock. So I am worried that running a stock sized 275/35zr18 in the front will throw off the car sensors. However if I would get a 295/35zr18 for the front, I have now added a taller sidewall tire to the front to compensate for the taller tire in the rear.
My current rear tire has a sidewall of 103.5mm, my current front tire 255/40 has a sidewall of 102mm.
Stock z06 tires have a sidewall of 97.5mm rear and 96.25 front
So if I went with a 275 I would have 103.5mm rear and 96.25 front
however if I went with a 295, I would have 103.5mm rear and 103.25mm front
Old 02-08-2011, 04:16 PM
FNBADAZ06
FNBADAZ06's Avatar
275's .
I run the Invo's at 275/35/18 and 345/30/19 with no issues on my C6 Z06.
The 295 is too wide for the 18x9.5 rim IMHO, and the sidewall will be pulled in at the tire bead (one of our local guys has this on his Z06). There's no performance advantage of running the 295 on the street, and possibly some negatives if you run them at an HPDE.
Old 10-10-2012, 08:17 PM
snowwhitec6
snowwhitec6's Avatar
which tires would u guys recommend for auto crossing but also little track use?
To 275 or 295 front tire with a 345 rear tire?
Quick Reply: 275 or 295 front tire with a 345 rear tire?
