Verizon Iphone 4 and Bluetooth.
Old 02-16-2011, 03:37 PM
Mcpousnret
Mcpousnret's Avatar
Default Verizon Iphone 4 and Bluetooth.
2009 Corvette coupe 3lt. Had an Android cell phone and the bluetooth worked with it just great. I had to have an Iphone when Verizon made it available and the bluetooth only works sometimes with it. I went to the dealer after APPLE told me to make sure that the firmware for the cars bluetooth was up to date. The dealer said it was.
Anyone else having problems? Is there a fix out there I don't know about? Thanks in advance for any help/suggestions
Mcpousnret is offline
Old 02-16-2011, 04:34 PM
bearman95
bearman95's Avatar
my bluetooth has always worked great with my iphone 3gs both in the vette and silvarado, maybe it the iphone 4 causing problems. My car is an 09 coupe.
bearman95 is offline
Old 02-16-2011, 04:45 PM
dd229
dd229's Avatar
I've seen the same in my 2011. It hasn't been so much an issue with the car as the phone. If I turn the phone off (completely power it down) and then back on it works fine. Twice this week I have had to do that. Sorry, no magic fix yet but will pass along if I find it. We're better of than my boss who just bought a Ferrari California - the iPhone doesn't work at all with his bluetooth.
Maybe two completely different issues, but having a problem anyway.
dd229 is offline
Old 02-16-2011, 04:46 PM
davidtcpa
Go Canes!
Support Corvetteforum!
davidtcpa's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I have an iPhone 4. Although the my 2007 did not come with a factory Bluetooth, the previous owner installed an aftermarket and it worked fine with my Blackberry, iPhone 3 and iPhone 4. Anyway, Bluetooth should be universal, and your iPhone will pair with any bluetooth signal. However, the frequency is not very strong and sometimes has issues and (in my opinion) is not the best technology to begin with.
davidtcpa is offline
Old 02-16-2011, 04:58 PM
Blaq Ops
Blaq Ops's Avatar
I have an at&t iphone 4 and my bluetooth works fine. It worked in my 09' coupe and now in my 10' GS. I use it almost everytime I'm in the car. It might be the different configuration of Verizon's iphone.
Blaq Ops is offline
Old 02-16-2011, 06:01 PM
Brian2010
Brian2010's Avatar
I have a 2010 and I have an iphone 3g it works great never had a problem.
Brian2010 is offline
Old 02-16-2011, 06:04 PM
not08crmanymore
not08crmanymore's Avatar
OP, is your bluetooth in discoverable mode?
not08crmanymore is offline
Old 02-16-2011, 08:31 PM
teuhl
teuhl's Avatar
What aftermarket install do you have? I have an 08 that I would like a bluetooth connection.
teuhl is offline
Old 02-16-2011, 11:24 PM
davidtcpa
Go Canes!
davidtcpa's Avatar
It's called a Tellphone 4200. Works great. It was already installed in the car when I bought it. It works though the stereo like a stock Bluetooth. When the phone rings, the radio mutes.
Old 02-16-2011, 11:28 PM
cnw
cnw's Avatar
iPhone works great in my GS Vert and Venza (Toyota). No problem.
Craig
cnw is offline
Old 02-17-2011, 09:06 AM
Mcpousnret
Mcpousnret's Avatar
Default Phone reset
I've tried everything. I have shut off the phone and restarted it. Works for a bit, then quits. Phone call is hung up between Bluetooth and phone. Never the same symptoms twice it seem.
Old 02-17-2011, 09:33 AM
waltershu
waltershu's Avatar
get someone with the same phone and carrier try their phone with your car.it may just be your phone has a problem with its bluetooth system.
waltershu is offline
Old 03-02-2012, 11:07 PM
ROD BROWN
ROD BROWN's Avatar
Default No problems
My 09 works great.No problem what so ever.I use Bluetooth every day.Works like a charm.
ROD BROWN is offline
Old 03-03-2012, 01:27 AM
Mregor
Mregor's Avatar
FWIW, I have 2009 3LT with Verizon iPhone 4S and it works like it should.
Mregor is offline
Old 03-03-2012, 08:58 AM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
http://forums.corvetteforum.com/foru...s-or-more.html
Vette_DD is offline
To Verizon Iphone 4 and Bluetooth.
Quick Reply: Verizon Iphone 4 and Bluetooth.
