New! C6 Clear Side Marker Lights - 4pc Side Marker Kit in Stock/On Sale
wow for all 4 ? and they fit the late model c6's? I'm not sure the standard c6 and the GS / Z06 have the same markers as they are a different part number from stock! But if you got yours for that kind of money and they fit - good for you....
Mine are suppose to show up tomorrow so we'll see how they look on a Cyber Gray GS
Mike
The fronts pop out after you gain access thru the lining in the front wheel well... Just remove a couple of the push pins, reach in and feel for a tab on the edge of the reflector, with a little pressure inward, toward to the front of the car, you should be able to push it(the reflector) out from the car. Twist out the assembly the holds the bulb in place and the reflector should be free. For the rear... remove the outside rear(far left/ right) taillight to gain access and then pop the reflector out the same as the fronts... Reverse the steps to install the replacements.
The fronts pop out after you gain access thru the lining in the front wheel well... Just remove a couple of the push ins, reach in and feel for a tab on the edge of the reflector, with a little pressure inward, toward to the front of the car, you should be able to push it(the reflector) out from the car. Twist out the assembly the holds the bulb in place and the reflector should be free. For the rear... remove the outside rear(far left/ right) taillight to gain access and then pop the reflector out the same as the fronts... Reverse the steps to install the replacements.
Platinum Supporting Vendor
Black
You know that black ones on an Arctic White Vette is going to look like DO-DO...can't you imagine that..black!!!! yep on a black vette or maybe dark blue, but not on a white///
#33
pm sent to mr rpi
#35
Well that kills it then. I have my tail lights sealed rather permanently and don't want to mess with them just to get clear side markers. Can't get to the rear markers through the (vert) trunk huh?
#36
no idea about vert. sealed permanently? you mean you didn't get the very popular, and inexpensive, gasket kit?
#37
#40
^^^ Looks good. And key we replied, thanks!!
