OBDII Problem
Old 02-25-2011, 01:47 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Default OBDII Problem
I suddenly cannot read the PCM. I just wrote some tune updates a few days ago and everything was working fine. Last night went out to make a change or 2 and could not read or write to the PCM.
HP Tuners wouldn't connect so I tried my trusty code reader and after about 30 seconds it gives me an error message. The message is "error".
I checked the fuse and is good. Cigar lighters is working and when I first plug in the code reader the lights flash but go off. Tuners has the green light with just the OBD2 plugged in, not the USB.
I have checked everything I know to check. You guys have any input. The car cranks and runs fine.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old 02-25-2011, 01:53 PM
TonyB.96LT4
TonyB.96LT4's Avatar
looks like you're in a loop.
Just guessing but if you have a pin loose/broken wire in the DLC that maybe the reason for your problem.
Old 02-25-2011, 03:06 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
Just checked the DLC and I have power on 16. Grounds appear to be very good on 4 and 5. Pins are seated and wiring looks to be OK.
Old 02-25-2011, 05:28 PM
keyplyr
keyplyr's Avatar
You might need to let it cycle about 10Xs to reset.
I had a similar event happen a few months back. It happened when I was continuously connecting to the OBDT II with my code reader getting some things done prior to a smog check. I think it was the *continuous* part
Old 02-25-2011, 07:14 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
This must have been it. It's working as usual now. I hate things like this.
To OBDII Problem
Quick Reply: OBDII Problem
