What is the best Clutch fluid to use?
Old 03-17-2011, 07:51 PM
redls3
redls3's Avatar
Default What is the best Clutch fluid to use?
what is the best clutch fluid to use on our mn6 corvettes?
i currently am using Prestone Synthetic Dot 4 brake fluid from autozone. is this a good fluid?
thanks
Old 03-17-2011, 07:55 PM
RicK T
RicK T's Avatar
Have you viewed, and are you following, the "Ranger" clutch fluid maintenance site and video? If not, here it is:
http://www.rangeracceleration.com/Clutch_Care.html
Dot 4 is the preferred fluid.
Old 03-17-2011, 08:15 PM
vettedoogie
vettedoogie's Avatar
Prestone DOT 4 Synthetic is right.
Old 03-18-2011, 09:04 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
We certainly have the GM DOT4 available if you'd like to use that as well.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 03-18-2011, 09:10 PM
gunterwalker
gunterwalker's Avatar
Location: Cape May, NJ; Guntersville, AL; Orange Beach, AL
any DOT4. I think they are all about the same.
Old 03-18-2011, 11:26 PM
Vette5.5
Vette5.5's Avatar
The owner's manual for my 06' ZO6 specifically state's using GM DOT-4 fluid, so just get it from Culley's parts house keeping thing's in spec.
Old 03-18-2011, 11:35 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
I use Motul 600.
Old 03-18-2011, 11:38 PM
saplumr
saplumr's Avatar
Received 1,251 Likes on 895 Posts
Originally Posted by Vette5.5
The owner's manual for my 06' ZO6 specifically state's using GM DOT-4 fluid.
Do you think the possiblity of making cash has anything to do with this?
Old 03-19-2011, 12:40 AM
SinisterC6
SinisterC6's Avatar
im using wilwood 600 brake fluid, 626 dry, 450 wet boil points
Old 03-19-2011, 12:43 AM
gunterwalker
No.... A car company wouldn't do that.
Old 03-19-2011, 08:49 AM
jackcasual
jackcasual's Avatar
I use Castrol SRF,but mostly cuz thats what I use for brake fluid in my C5 track car.
Old 03-19-2011, 08:56 AM
6Speeder
6Speeder's Avatar
Castrol GT LMA, synthetic Dot 4, has a higher than most wet boiling point and is very clear colored, like light straw. Makes it easy to tell when it changes color.
Old 03-19-2011, 11:21 AM
tjl5709
tjl5709's Avatar
Prestone 4 from Autozone. Price is right, and easy to get. Don't over-think it.......
Old 03-19-2011, 11:26 AM
Kenny94945
Kenny94945's Avatar
Yes, don't over think it.
Best is freshest...so bleed/ the flush system at least yearly.
Best is also not to mix brands...so stick with one.
Old 03-19-2011, 11:49 AM
diyguy
diyguy's Avatar
OPPS.. I just did the suck it all out.. replace, suck it out, replace, pump clutch, ....did this about 8 times before it was clear again, BUT.. I used DOT 3 ?
Should I re-do it with DOT 4 synthetic?
Old 03-19-2011, 11:53 AM
saplumr
saplumr's Avatar
My guess is your system is contaminated now. I'm sure it makes a difference. I be checking with my GM dealer pronto.
PatriotZ
PatriotZ's Avatar
Location: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Plumber dude is very perceptive right on
To What is the best Clutch fluid to use?
Old 03-19-2011, 12:54 PM
fperra
fperra's Avatar
Me too. If you want the best, this is it. About $75 a bottle.
Old 03-19-2011, 01:05 PM
b4i4getit
b4i4getit's Avatar
I think the GM branded is a bit expensive. The Prestone is just as good according to Ranger.
Old 03-19-2011, 01:12 PM
BEZ06
BEZ06's Avatar
Don't worry about it - all modern brake fluids are synthetic and DOT 3 & 4 are completely compatible.
DOT 4 has higher boiling points than DOT 3, and the clutch actuator is down close to hot parts at the back of the engine such as the headers, so I'd recommend just do your Ranger method clutch fluid swap again with some DOT 4.
I use the Prestone DOT 4 stuff in the clutch on my track Z06 and have never had any clutch problems. At less than $3 for a 12 ounce bottle I can do the Ranger method quite often to keep my fluid clean at very low cost!!
The one brake fluid you don't want to use in your brake system or clutch is DOT 5. It's a silicone based stuff that IS NOT compatible with DOT 3, 4, 4+, or 5.1, and if you do get it into your system you'll need to flush and clean the system to get it all out of there.
Bob
Quick Reply: What is the best Clutch fluid to use?
