Do z51 brakes fit base c6
Was wondering if you can use Z51 brake setup with base wheels?
I'm selling a set and just want to make sure they fit base C6 wheels.
Location: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
the deal
Calipers are the same... pads are more agressive, caliper mounting brackets are different to allow for slightly bigger rotors w/ holes drilled in them. that's it.
Does anyone know if the brake pads would be the same for a base model and z51 rotor. I was noticing brake pads used for my buddies base a little smaller than what I have on the z51 rotor. If anyone can chime in.
