How to use IPOD without nav or XM??
Old 04-26-2011, 04:05 AM
victoryredFTW
victoryredFTW's Avatar
Default How to use IPOD without nav or XM??
I've been searching endlessly to find a solution! Is there any way you can connect your IPOD in a corvette that doesn't have navigation or XM?
I know I have the option of an FM transmitter, and of course I can swap the radio unit for one that has a direct input. Any other solutions somebody has thought of? Thanks! much appreciated
Old 04-26-2011, 05:13 AM
Don-Vette
Don-Vette's Avatar
I just plug mine into the aux. jack on front of radio.
Old 04-26-2011, 06:02 AM
Mischief
Mischief's Avatar
I have been checking around as well and haven't found anything that would be a suitable replacement. I plan to swap out the factory unit with an aftermarket piece. They offer more options for connectivity as opposed to working with the factory units that are not equipped with an auxiliary jack.
Old 04-26-2011, 07:39 AM
tampatopless
Support Corvetteforum!
tampatopless's Avatar
I checked out everything and the only thing that didn't involve switching out the HU or tapping into the XM was the FM transmitter.
I use it and yes, it sucks, but I guess it's OK for the time being.
Old 04-26-2011, 08:15 AM
Augustus_Maximus
Augustus_Maximus's Avatar
same here.....
I use the ipod and/or the blackberry.....
A.
Old 04-26-2011, 08:28 AM
ArcticLS3
ArcticLS3's Avatar
Do you have this little hole next to your CD player slot? If so - just run a 3.5mm cable from your Ipod to it and you are done. Otherwise get a PAL and that works with any radio I believe.
Old 04-26-2011, 08:40 AM
KarlK
KarlK's Avatar
Location: Beats UD regularly playing 3D chess, and at life
I had an 06 with the stock head unit. I installed and Alpine with the Ipod connection in early 07. After about a year, I was getting some electronic gremlins. The Alpine was causing some aftermarket communication issues, causing some codes.
Removed the Alpine, installed an 08 head unit with the front Aux jack. Had it married to the computer, works great.
Old 04-26-2011, 08:52 AM
weathermaker
weathermaker's Avatar
Originally Posted by LS3 MN6
The GM PAL sold by Ray Kawal has software compatible with Nav, Non-Nav, XM, no-XM. Basically all C6 radios. Check out his site.
Except '05s!
Old 04-26-2011, 11:03 AM
unixcorn
unixcorn's Avatar
I bought a PX-AMG adapter but after two trips to the dealer to try and enable it (it mimics the XM unit or something), was unable to make it work with my 07 1LT coupe. I ended up buying a Pioneer HU pre-wired from Double D Mods. I am much happier with the new HU and I can now control my iPhone from the radio and even watch a DVD if I want. Only when stopped, of course. Since Dennis pre-wired the unit, the install was a cinch using instructions from the forum. I told myself the HU was all I was doing but now I am thinking about speakers...LOL. It's endless.
Old 04-26-2011, 12:10 PM
victoryredFTW
Thanks for the replies. I forgot to mention that I do not have an aux jack. I will check out the PAL..thanks for the advice!
Old 04-26-2011, 01:11 PM
stevestig
stevestig's Avatar
For what it's worth, i wanted to stay with the factory HU. I tried 2 different ipod integration solutions before the PAL was available.
They both stunk. The PAL does the best it can with the limited interactions an outside device can have with the standard factory HUs. My experience, the PAL solution is much more reliable and stable.
Ray has a bunch of detail including pictures here:
http://www.kawal.net/vettemods.htm
Old 04-26-2011, 02:42 PM
ArcticLS3
ArcticLS3's Avatar
Maybe you could find a stock unit with the AUX jack for cheap in the for sale section and just swap them. That is if you like the system as it sits now and just want the IPOD connection.
For price reference:
http://forums.corvetteforum.com/c6-p...eo-2006-a.html
Kind of old, but:
http://forums.corvetteforum.com/c6-p...-09-radio.html
http://forums.corvetteforum.com/c6-p...head-unit.html
Old 04-26-2011, 03:12 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Let us know how it goes or if you find any other options.
Brent
GM Customer Service
Old 04-26-2011, 03:14 PM
cclive
cclive's Avatar
Ray knows his stuff!
Old 04-26-2011, 03:33 PM
Sunset-C6
Sunset-C6's Avatar
How about this from Best Buy.
http://www.bestbuy.com/site/iSimple+...&skuId=1175181
Compatible with Chevrolet 2003 - 2010 Avalanche, 2003 - 2005 Cavalier, 2004 - 2010 Colorado, 2005 - 2010 Corvette, 2007 - 2008 Equinox, 2009 - 2011 Express, 2003 - 2011 Impala, Suburban, SSR, Silverado and Tahoe, 2003 - 2007 Monte Carlo.
Old 04-26-2011, 04:09 PM
GaryJK
GaryJK's Avatar
When checking into the PAL unit, don't let the very difficult installation of the Version 1 PAL scare you. Ordering a PAL unit and Harness from Ray Kawal makes installing the PAL a very simple, quick, and easy job. With in an hour you will have it installed.
Gary
Old 04-26-2011, 04:43 PM
lawnmore
lawnmore's Avatar
To How to use IPOD without nav or XM??
Old 04-26-2011, 05:12 PM
0Double D Mods
Former Vendor
Double D Mods's Avatar
St. Jude Donor '12-'13
C6 CORVETTE ISimple ISGM575 05-10 Ipod/Iphone install kit
The ISGM575 (PXAMG and PGHGM5) directly connects your iPod to your radio allowing you to browse your music, by Artist, Album, Genre, and Playlist from the radio controls. This direct connection eliminates the need for noisy FM modulated solutions, and also keeps the iPods internal battery charged. The interface is expandable, by adding the HDRT you will receive digital radio stations that can not be received with a standard tuner. Experience HD Radio and hear FM in CD quality, and AM at FM quality!
$124.99 shipped
we have shipped a couple hundred of these with no issues
http://shop.doubledmods.com/searchqu...ywords=isgm575
Old 04-26-2011, 05:31 PM
5knives
5knives's Avatar
$124.99 shipped
Is installation the same as the PAL? Will this work on an '07 1LT w/o Nav/XM?
Old 04-26-2011, 05:46 PM
PCMusicGuy
PCMusicGuy's Avatar
These solutions are quite overboard, especially if you don't use an iDevice. Really, all I want is a cheap, clean way to add a 3.5mm input jack to my factory non-Nav, non-XM, non-Bose radio.
Basically, add the input jack that the 08+ base radio received. The only way I've seen to add something like this is to splice a switch and relay and then select between the CD player and input jack.
Quick Reply: How to use IPOD without nav or XM??
