*****((PICS/HOW TO)) Rear ZR1 widebody install here in CT *****
Cruise-In VII Veteran
INSTALLATIONS available here in CT, or I will drive anywhere in the NORTHEAST(call for quote)
ORLANDO/Cocoa Beach FL location also available for C6 WB upgrades
I also travel to FLORIDA 6-8 times per year..............
I drove out to 'cthusker's' shop in western CT yesterday afternoon to help out with the rear WB install
ZR1, Z06, and GrandSport's from GM all use the same rear quarter, these quarters were supplied from RPI
Removal of OEM panels will take about an hour, Torx T15's along front and top, remove the T15's along the top of the rear cover also
You'll find x9 7mm screws for the inner fender liners, all in plain sight, one up front facing upwards into the rocker, 4 in line out back on the lower valance, remove that 'base' fender liner out of there, the brake duct will stay with the liner
Unplug that rear marker light
Ok, now you can see the 5 fasteners securing the quarter to the rear cover,
1. Remove OUTER taillights, this allows the x2 forward facing 8mm bolts to be easily removed
2. now facing aft going inside the fender well, you'll see the x2 10mm nuts
3. Lower attach point is a 10mm bolt/nut(5th and final at this seem)
4. x2 10mm bolts attach the 'body seam plate' to the bathtub
Removal of OEM panels, this is where you will want some help
1. With someone pulling aft on the rear cover, you'll be able to pull the bottom of the quarter out and up, NOTING the fitment UNDER the door seal and HALO area upon removal
2. place 'base' quarter away from WB project, note how anemic it looks compared to the aggressive flanks of the ZR1/Z06/GS piece
INSTALL, reverse process, I always install everything 'loose', being sure to align front/top/aft gaps
QUESTIONS???? POST or CALL, number is under avi
Wheels: CCW's wrapped in 325/30 Nitto INVO's, finish is very unique
Ride height? it will lower once driven, standard 'jacked' look
QUESTIONS?? don't hesitate to post or call, time involved will be about 3-5 hours depending on skill level
ErnieN85 (02-26-2016)
1 Post
Hi steve,
I'm in southern rhode island and am thinking of using your services this coming winter with the rear widebody install. My vet is a black vert, what is the cost of this mod with the panels painted and installed?
I have the owner go direct to www.gmpartshouse.com and use a local painter, I have a small group that does outstanding work
My core work is motor/drivetrain/suspension/brake upgrade and replacement, this(widebody) is just a skill I acquired for fun
The C6 HUD conversion has been a big hit lately, 26 cars so far this year
30 HUD conversions complete
A couple of www.aacorvette.com Vortech supercharger installs last month, TR6060 upgrade last week and another www.rpmtransmissions.com 4L60E upgrade on a 1997 C5 from Maine
39 HUD installs complete now, SoCal trip was great
www.gmpartshouse.com get the panels direct from Patrick
Looks great and the price with you doing the install is excellent.
quote? I only get involved with installation, I have a local painter here in CT, typical charge is 250/300 per panel for paint
parts and paint I do not supply
