Should we use fuel injector cleaners?
#41
Gentlemen, when is the last time you saw a dirty or fouled fuel injector? Use a premium top tier fuel and spend your fuel additive money on something that will really make your car faster or more fun to drive. Fuel additives = waste of money = marketing. Also, for those of you who think that if a little is good, a lot will be great, you are wrong. Too much of certain additives can actually poison the system and cause expensive damage. If you must use an additive, follow the directions. Bottom line, you get all the fuel treatment you need in the fuel you are buying.
NSF
#42
As noted by others, less fuel to deteriorate while in storage. With the use of ethanol, which has an affinity for water, gas will "gum up" more and in storage, may cause you issues when it's time to crank it back up. My enduro bike came with instructions to drain tank and carb after each race. I was running pump gas (premium) with octane additive and ethanol treatment and, if not drained, I usually had to re-jet due to clogging. Switched to full race gas and now not an issue. Would think a Vette with computer controlled injection wouldn't have the problem but ????
#44
Back in the day of GASOLINE it was better to store the tank full. Now with the Government mandated corn liquor fuel we have to use, it turns to **** after a few months. I would add stabilizer to whatever was in it and hope for the best.
Mark
Mark
#45
Use seafoam in the tank once or twice a year. We don't have direct fuel injection like the C7 so we don't have to worry about the crappy carbon buildup. I owned a car with direct injection before...never again.
#49
Living in Nebraska most all of the premium gas has at least 10% ethanol in it as an oxygenator and it is used to raise the octane rating.
I always top of my tank for the winter storage and have never had any problem come spring time when I start her up.
#51
Received 1,500 Likes
no need, however, I do put Techron once in a while for the gas gauge...what I do recommend though is a few hundred mile run once in a while to keep the engine running clean
