Where on a C6 do you hook up a Canus obdII
Moderator
Received 3,579 Likes
The port is directly under the sterring column
Mercifully, John chimed in first to save you countless posts of folks telling you that you plug it in to the OBDII port.
As John noted, if you follow the steering column down from the wheel towards the floorboard and just behind the panel beneath you will find the port about centered under there up under the dash.
