how to replace my fog light?
Old 07-12-2011, 08:20 AM
Randy_medion
Randy_medion's Avatar
Default how to replace my fog light?
Can't find a way how to replace the lamp can someone help me how to do it?
Old 07-12-2011, 08:47 AM
gp56
Support Corvetteforum!
gp56's Avatar
Are you talking about replacing the bulb or the assembly? If its the bulb remove the push pins on the front part of the wheel well and get your hand in there. Will have to turn the wheel all the way to get clearance.
Old 07-12-2011, 09:02 AM
MHFontaine
MHFontaine's Avatar
St. Jude Donor '05
Here's what has worked for me...
Remove the wheel on the bad fog side of the car.
Remove the pins and screws inside the wheel well.
With pins and screws removed, pull back wheel well lining
The bulb is connected to the light blue and black clip in this pic. A counter clock-wise turn is all that's required to remove bad bulb (you don't have to remove the entire fog light housing). Once removed, gently pry the black clip away from the bulb to remove it from the connector.
Replace the bad bulb, and put it all back together again
FYI...here's the rest of the story...here's why/how I know how to change a fog light
http://forums.corvetteforum.com/c6-c...the-world.html
Edit: If you have to remove the complete fog light housing, see the above link.
Good luck !
Old 07-12-2011, 09:26 AM
bbudman
bbudman's Avatar
I just replaced my fogs with the HID kit from CorvetteMods. I didn't have to remove the wheel, just turned it to full lock towards the opposite side from which I was working. Removed screws from fender liner and the first panel clip. Then pulled the liner back far enough to do what needed to be done. It took no time to do it and saved me from removing the wheel.
Old 07-12-2011, 12:38 PM
diverdan
diverdan's Avatar
You don't NEED to remove the wheel to do the access the back of the fog light, but it makes it much much easier if you do, particularly if you are upgrading to an HID setup.
Old 07-12-2011, 12:40 PM
Randy_medion
Thanks for your help everyone! my H.I.D's work great again!!
Old 03-25-2017, 04:58 PM
ccounsell
ccounsell's Avatar
I just replaced my OEM bulbs with LEDs that are much whiter & brighter! Did not remove the wheels, but did remove my watch; it is tight, but doable.
Old 03-25-2017, 08:56 PM
WW7
WW7's Avatar
Your 6 years to late........WW
Old 03-25-2017, 11:05 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
Where did you get the LED's? Is there a part no., or product no.?
Old 03-26-2017, 11:27 AM
Dutch08
Dutch08's Avatar
I got mine at AutoZone. They are nice white, bright and much better than the old bulbs. Good price too. Autozone stocks them on the by the lamp number.
Old 01-04-2018, 07:04 AM
Troika
Cruising
Troika's Avatar
I've seen a lot of instructions related to the fog light bulb replacement / upgrade, but haven't seen anything related the replacing the fog light housing. Any suggestions? Mine was knocked out of the socket by some road debris and I need to reinstall. I'm assuming it might be pretty straight forward once I've removed the inner fender well lining however thought someone might have some tips or suggestions.
To how to replace my fog light?
Quick Reply: how to replace my fog light?
