Post your lowered C6
Old 08-17-2011, 02:37 PM
  #41
Tikiman12
Tikiman12's Avatar
Originally Posted by Sheldon729
Eibach drop bolts but not drop all the way in rear to leave some rake
wow, I never liked those wheels until right now on your car lol. Looks great
Old 08-18-2011, 01:05 PM
  #42
Sheldon729
Sheldon729's Avatar
Well thanks. They wont be on for much longer tho.
Old 08-18-2011, 01:27 PM
  #43
C7&7
C7&7's Avatar
Lowered on adjustable LG coil-overs:
Old 04-03-2012, 12:06 AM
  #44
EVL JAKE
EVL JAKE's Avatar
St. Jude Donor '12-'13
Lowered on stock bolts, rear bushings cut to last groove and raised 3/4 of and inch.
Old 04-03-2012, 09:51 AM
  #45
NSANEC6
NSANEC6's Avatar
Originally Posted by mcandrew67
Lowered on stock bolts with bushings cut in half.
David
MY MOST FAVORITE CAR ON THE FORUMS
Old 04-03-2012, 11:03 AM
  #46
RabidVette
RabidVette's Avatar
Slammed on Phadt coilovers...
Old 04-03-2012, 11:43 AM
  #47
Grandsportgodzilla
Grandsportgodzilla's Avatar
What is exactly needed to lower my c6 grand sport the way it looks online is I just buy the lowering bolts and install them...is anything else needed or suggested?
Old 04-03-2012, 11:49 AM
  #48
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
Old 04-03-2012, 11:50 AM
  #49
RabidVette
RabidVette's Avatar
Maybe a little waterproof grease to reduce abrasion and stop any potential squeaks that may come up.
Another option is to cut your factory bushings using a PVC pipe cutter.
I cut the OEM bushings on my car before switching to coilovers, and they held up fine. I have heard complaints about the longevity of aftermarket lowering bolts, so I'm not sure which would be the best option.
Old 04-03-2012, 11:56 AM
  #50
Grandsportgodzilla
O ok cool ya that seems like a good idea how would you go about cutting those bushings like where would u cut
Old 04-03-2012, 11:58 AM
  #51
ScottJ03
ScottJ03's Avatar
Old 04-03-2012, 12:07 PM
  #52
RabidVette
RabidVette's Avatar
Go to Lowes, Home Depot, etc. and get a PVC pipe cable saw like this:
http://www.generaltools.com/858--PVC...SAW_p_121.html
Jack up a corner of the car and remove the wheel. Then you will have to jack up the spring to take the weight off the A-arm. Place a jack (a bottle jack is best, but any jack will work) on the end of the spring as close to the A-arm as possible. Place upward pressure on the spring until the bushing on the lowering bolt is only making very light contact with the A-arm. Then loop your PCV cable cutter around the ridge in the bushing, and begin sawing back and forth until the bottom of the bushing is cut off. Adjust the bolt to the desired height, place some grease on the bottom of the bushing, and lower the spring back down onto the A-arm. Move to next corner and repeat.
Old 04-03-2012, 12:23 PM
  #53
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
Originally Posted by ScottJ03
-snip-
Old 04-03-2012, 12:28 PM
  #54
petermj
petermj's Avatar
a corvette friendly driveway would be a good start
Old 04-03-2012, 12:34 PM
  #55
shootincyclone
shootincyclone's Avatar
Old 04-03-2012, 12:35 PM
  #56
DonOH
DonOH's Avatar
That is what I was thinking. My driveway is flat to the road but my stock height C6 scrapes way too often. Even leaving the Corvette Club meeting the air dam scrapes. You better live in the right part of the country to lower one.
c5arlen (03-23-2023)
Old 04-03-2012, 01:08 PM
  #57
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
thanks
To Post your lowered C6
Old 04-03-2012, 01:30 PM
  #58
g-townmach
g-townmach's Avatar
Lowered about .500 inch with cut stock bushings.
Old 04-03-2012, 01:48 PM
  #59
OneBadZ06
OneBadZ06's Avatar
St. Jude Donor '08-'10
Old 04-03-2012, 01:58 PM
  #60
EVL JAKE
EVL JAKE's Avatar
moar!!
Quick Reply: Post your lowered C6
