Hardbar lowering bolts .....
I use them and have no issues with them. Quality pieces, easy to install, easy to adjust, gives you a nice stance.....I even have a brand new extra set (4 bolts/4delrin pads) laying in the garage I'd sell to you if you want them?
Slammed on Hardbars...btw, give the front end some time to settle...I drove it around for a few days and thought it was done, but it ended up dropping and added 0.25" the more I drove it. I also wanted moar low in the front, so I switched them out for Corvette mod bolts with slimmer pads.
Your timing is excellent - I was going to post this morning.
After a long trip ( 950 miles ) to the ALMS race at Mid-Ohio this weekend we got caught in the rain a couple of times. I find that the delrin pads start squeaking lke crazy after a "rain" drive. I have to lube them - lube between the pad and where it sits in the A-arm to fix it, but it seems this fix lasts less and less each time I do it....
One thing that concerns me is that the delrin pad of the hardbar bolts is much smaller in diameter than the OEM bolts-pad - so I am wondering if this is exerting more pressure in the area it contacts the A-arm (smaller pad and same weight = more PSI). My concern is that the super-tough delrin pad will damage the saddle in the A-arm and I'll have to replace them.
I would appreciate some good input on this......
vetfever
vetfever
I know what you mean about the small pad sitting there in the A-Arm, but I checked mine last week and the saddle still looked good...no wear or grooves. I do however, go in there and clean all the pebbles and dirt out at least once a month. I used grease when I first installed them, but have since cleaned the grease out clean. No issues still. I think they are good pieces; however, the Hardbars will not slam the front end of a Z06.
I have seen Hardbar bolts slam base vettes though. Not sure if it has to do with the higher spring rating on the Z?
vetfever
vetfever
LFZ...Can you shoot me a PM with the price you want for the bolts? My front is pretty low but now that I went from 20's in the rear down to 19's, I need to do something about my wheel gap.
P.S. your car looks great slammed.
I dropped mine on stock bolts that i cut the rubber down to the last rib. Car settled very nice. I saw no reason to buy the aftermarket bolts, when cutting the stock ones would lower the car to the same level. And then i heard about some aftermarket bolts failing and making all sorts of noise, needing grease..blah blah.. it just wasnt worth it for me. I drive my vette daily, rain or shine. So all that was takin into consideration.
These pics needed some tire shine done. But i had just got the car back from paint. So i hadnt detailed it yet.
I'm also having issues with the Hardbar lowering bolts squeaking while driving it in the rain. What other lowering bolts avoid having this noise? Is the only other option WCC bolts but they might have issues down the road of the rubber pad failing right?
http://www.ebay.com/itm/05-09-CHEVY-CORVETTE-C6-Z06-LOWERING-SUSPENSION-KIT-/250415557283?hash=item3a4dee2aa3&item=250415557283&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
