DIC Says "Check Coolant Level"
Within a week of taking delivery of a 2011 coup, the DIC flashed a message to "Check Coolant Level." The message was gone after checking the coolant supply and restarting the engine. The dealer's service department ran the computer diagnostics, nothing indicated. Service adviser said: Air bubble in the cooling system.
Message reappears a few weeks later. Message again disappears when the engine is turned off, then restarted. Service department ran diagnostics without a problem code being identified. Service advisor said to bring it in, without turning the engine off next time it happens.
This morning the check coolant level message appeared again. Vette taken to service department which verified the message was actually being displayed with the coolant level within normal levels. The service department has been interacting with GM Tech Support. Some number of computer tests are being run. Hopefully the problem will be repaired without creating new one(s) and life will be good once again.
If this does not work out, can anyone recommend a good exorcist?
The Corvette C6 doesn't have a coolant level sensor. Coolant level is a calculation done by comparing coolant temperature to RPM to determine if the proper level of coolant is present based on what the car is doing. In the event of a level issue being reported when the correct level of coolant can be observed in the reservoir, the dealer is able to recalibrate the table in the HVAC module (which is where the calculations are done for the coolant level algorithm.)
MidWestKev (06-09-2016)
However, when I first bought my Corvette, the check coolant message appeared in my DIC. I checked the coolant and appeared to be at the appropriate level. I added some coolant anyway (without it overflowing), and the light did not come on until recently (two years later). I added a little more coolant and the message has not reappeared.
Might want to try adding a little coolant (or distilled water, or a mixture of both), to see if this resolves your problem.
Good luck!
coolant
c6 2007 90,000 k i had the same message come on' check coolant level'
2 times, went away when i released the pressure cap, all levels were correct, it came back weeks later, this time i squeezed the top hose several times with cap off problem never returned
My dealer will replace anything I ask them to do under warranty, so we started with thermostat after the MOntreal incident, didn't help.
We put some dye into the rad fluid, drove it a couple of hundred kilomoters and then looked at the whole engine bay under black light, no leak.
They have ordered a new temperature sensor for me and will change that when the part comes in. My guess is the the temp sensor. As you saw from another post, the car uses software (cheaper than hardware) to determine coolant level.
If it happenes again, switch the DIC over to coolant temperature. When i did the DIC displayed, 220, then 170 then 210, then 160 and kept changing, which tells me it is bad. And if it goes bad then it would give us the coolant level error.
I will let you know what happens after they change the temp sensor
Cylon, after all of the dealership visits you’ve had to make, I’d suggest you call GM Canada Customer Assistance so they can look into what’s going on. Their number is (800) 263-3777.
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
Maybe the angle of your car is setting the DIC message off?
Crown of the road, angled driveway, nose dive under braking etc.
Then, once the car is level again all systems check out as OK when you are investigating.
I'd add a 1/2 cup of distilled water, squeeze the radiator hoses for air bubble bleeding and call it a day........before returning to the dealer.
Since this is a new Vette the issue can be worth investigating fully... so return to dealer after you rule out the easy DIY (do it yourself) fix above.
Good hunting.
Good hunting.
Received 1,919 Likes
One bad sensor, matches the indications, intermittment, no actual mechanical of a fluid problem.
Ramblin On, please let me know how everything goes this time at the dealership. If you’re still experiencing this message after your visit, I can look into it further for you.
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
This has happened several times on mine but did not concern me as every time I looked the reservoir was full. Interesting how the correct level is determined.
hot, 90+ and while in stop and go traffic in downtown city streets, or re-strating car after being off for 15 minutes again in a hot situation
Latest episode it happened within a mile of home. Speed in the 0-45 mile range. Morning temp in the upper 70's. went directly to the dealer. The vette has been there since 10:45 yesterday while service staff "tested" the car. No word as of 5:00pm today on whether or not they have identified or fixed the problem.
Received 1,499 Likes
My issue began on hot day, drove about 100 miles, stopped for lunch. Then drove about 10 minutes, parked and shopped for a bit. Then hit the highway home at about 75 mph. 10 to 15 minutes into the drive the message hit. Temperature was running in the 90's.
I am by no means a technical expert, but given the fact that people here have said that the car does not have an actual sensor to measure the level and that you have visually confirmed it to be topped up, it would appear that it this is a design flaw and that hot engine temps could trigger such a warning. However, I would have thought that you would get an overheated engine warning, if the car has such a warning. The other day I saw my engine temperature go up to about 109 C/228 F but didn't get any warnings.
FYI - the engine temperature gague never got over 220 f. Nary a sign of over heating ever appeared, even after driving 40+ miles at 75 mph after the message was cancelled. I believe a computer gremlin is possessing the system. The dealer's service department is still working on it.
Picked up the C-6 yesterday (Thursady) about 5:00 pm. Service Consultant said they worked with GM Tech over 2-1/2 days and ended up doing a "reset."
I drove it home, about 5 miles. Garaged it over night. Drove about 8 miles this morning. Parked it in the sun until about 4:55 pm.
Started home, within 5 minutes, the "Check Coolant Level" message came on gain. Took it directly to Casa Chevrolet (Albuquerque). Service consultant saw the message, he said they will try again.
Richard
Ramblin On... I have always gotten that message anytime the computer didn't "think" the engine temp got up to temp fast enough, no matter what time of year. However, it does happen more often in winter. I went through the same as you a while back, and eventually gave up and had it tuned out. It happens because the computer see's lower than expected engine tempratures based on an algorithym of outside temp, engine temp, and other parameters. If it thinks the engine temp is too cold, it assumes the coolant level is low, and that the engine temp is false. The temps will then bounce around on the DIC a while until it finally reads XXX. There are tuners out there that can change this, which is exactly what I had done. It drove me crazy when I first bought this Vette. It really gets bad if you do any mods and use a 160 or 180 degree thermostat. Good luck.
