Clear bra failed!
Old 08-21-2011, 02:22 PM
jversluis
jversluis's Avatar
Default Clear bra failed!
Road trip to Woodward Dream Cruise in Detriot. Took a rock or something at 80 plus and heard it hit windshield. I assume it hit the hood first, cut the bra and chipped the paint. Now I need that section of bra removed, fix the chip and replace bra. Question is best way to fix chip. Touch it up, let dealer respray that area or any suggestions. Chips never look the same after touch up. The good thing is that it is at outer edge of hood. Thought clear bra would prevent this, but not.
Sucks..
Old 08-21-2011, 03:14 PM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
I would touch-up the chip, a good job and only you will know where it was. Interesting that the clear bra failed as so many people swear by them.
Old 08-21-2011, 03:20 PM
rayk
rayk's Avatar
I wouldn't respray. I would go with DR Colorchip.
http://www.drcolorchip.com/
Old 08-21-2011, 03:21 PM
MARSC6
MARSC6's Avatar
Just a thin sheet of plastic. Not going to stop much.
I would just touch up the chip and not bother wasting the money on a clear bra again.
Old 08-21-2011, 03:22 PM
RicK T
RicK T's Avatar
Bummer......but Clear Bra isn't armor. Hit something big enough/fast enough and it's going to penetrate.
That chip might be okay with a quality paint touch-up, maybe a good body shop. Might want to ask in the Car Care Forum too for opinions from all the detail people. Good luck.
Old 08-21-2011, 03:29 PM
Tim Coltrain
Tim Coltrain's Avatar
Default Bra in General
I believe that a bra has a perpose. it absorbs energy resulting in less damage. In the long run is better I recon. Just thinking outloud.
TIM$VETT
Old 08-21-2011, 03:34 PM
Blaq Ops
Blaq Ops's Avatar
The clear bra probably protects against a lot. I wouldn't say it failed. You hit a rock going 80 mph!! You can't put a clear bra on, let me hit your car with a brick and think everything is going to be ok.
Old 08-21-2011, 03:40 PM
RedVette84
RedVette84's Avatar
The clear bra will protect against most small chips but anything of size and at that speed you would have to have one of the heavier clip on vinyl and fabric bras to stop it.
Old 08-21-2011, 03:50 PM
white90conv
Support Corvetteforum!
white90conv's Avatar
I would definitely touch it up. Repainting has risks. There is a good chance of a slight color mismatch and the panel will be more prone to chipping.
Old 08-21-2011, 04:02 PM
pro-tect mobile
pro-tect mobile's Avatar
First off, what type of clear bra do you have on there? Some people are going the cheap route and actually getting clear vinyl as opposed to real paint protection film.
A gravelometer is used to test surfaces for chip resistance. As you can see in the video below (just the first one I found...) that half inch stones are chot at the film directly, not at an angle like the rock would have hit your hood. The film stopped all of the damage. From looking at your pic I am inclined to think that either you dont have genuin paint protection film on oyur car or the object that hit you was large. I would also like to see the painted surface after you remvoe the film... as sometimes the damage is in the film and not the paint.
http://www.youtube.com/watch?v=5hv1E8db10k
Old 08-21-2011, 06:45 PM
bluman
bluman's Avatar
Pal...seriously...
you had a rock strike your car at 80 mph...
think about it !
Old 08-21-2011, 07:06 PM
gee350z1
gee350z1's Avatar
Fail ? what do you think the clear bra is made from ? at 80 mph your lucky thats all the damage you got.
Old 08-21-2011, 07:19 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,095 Likes on 807 Posts
You hit a good size one to do that and I would try touch up first and if that does not work then I would do a respray
Old 08-21-2011, 09:18 PM
RadarP3C
RadarP3C's Avatar
Your example is a little misleading. A rock shot directly will do less damage than one at an angle like the OP's hood. Hit at an angle, the rock can act like a knife and cut through the clear bra protection and do it's damage. Hit straight on, the rock only compresses the clear bra and the energy is absorbed. That is where the clear bra has the advantage up to a point.
Old 08-21-2011, 09:27 PM
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,419 Likes on 2,266 Posts
Probably would have been worse without the clear bra.
Old 08-21-2011, 10:41 PM
pro-tect mobile
A rock hitting it at an angle would skip off the surface... which is why most of the rock chips cars get are on the flat surfaces facing the road. The more energy behind an object the more damage is going to be done...
Old 08-22-2011, 07:36 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
There is a limit to just how much protection a clear bra can provide and it looks like in this case, the rock, speeds, direction and impact velocity was beyond what could be stopped. Physics can't be ignored but be thankful that the bra was on there as it could have been a lot worse.
To Clear bra failed!
Old 08-22-2011, 07:42 AM
jversluis
jversluis's Avatar
Thanks for all the feedback. I will go with touch up and rebra that area. The bra is Avery Nano sheild. Suppose to be one of the best. Will post results when I get it done.
Old 08-22-2011, 08:08 AM
MachAll 2005
MachAll 2005's Avatar
Good Vid .. shows exactly what this type of product is supposed to do. We have a ClearShield that has shown some minor direct and glancing impacts with no damage. We had 2 pcs of dirt clod hit a glancing blow last weekend which left surface scuffs that buffed out....well worth its price.
Old 08-22-2011, 08:56 AM
luvchevs
luvchevs's Avatar
I have a clear bra on my DD and have been very happy with the protection it has given the front of the car.
Dave
Quick Reply: Clear bra failed!
