C6 Tires
C6 Tires
I have a 07 c6 coupe. I bought the car with kumho tires on it. The pressure was around 32psi and the car runs really good with this pressure. The tires max is 50psi and 51psi front and rear. Should I up the pressure or leave it where it is. Some suggested 34psi at all times. Is this correct or should I at least bump up the pressure to around 40 psi? thanks
Greg
Greg
Definitely don't pump them up to 40. Some folks here run 2 or 3 lbs more than the GM sticker that says 30, but don't run more than that.
Greg
Greg
Greg
Greg
Retired & lovin' it!
Greg
Greg
Location: Stafford VA, home of our wolf den. No house break ins to date.
30 psi on the door jam is for a reason... that gives you the proper contact patch size, the proper flexing of the casing and the proper reaction of the belts and support wedges in the crown edge for that size tire on the car.. a lot of work in engineering went into that with GM. You can run 32psi, but run it on the front only... it gives just a tad advantage for crown edge support.. the tires casing and structure wont really notice a true diff in pressure unless you drop or bump by 3 psi...
ps. and like stated, always check/adjust tire pressure when the tires are cold... meaning they have set for a few hours to cool down. if you must check them hot.. add 4 psi.... in other words.. to be at 30 psi cold... if the tire is hot, set it at 34 psi.
Try to check the pressure when the tires temperatures are approximately equal - such as parked in the shade or after sitting over night. Right down any needed pressure adjustments before driving to the service station. That way you will know how many PSI to add after you drive to the sevice station and the tires are warm.
If parked in the sun, the tires in the sun will be hotter and probably 2 or 3 psi more than those in the shade (assuming they were equally inflated when cool). If you adjust pressure to equalize them, the hot tires will be underinflated, relative to those that were cool, when you drive far enough that the tire temperatures equalize.
CF Senior Member
Adjusting and trying to equalize tire pressures when tires are cooling down and/or when half the car is in the sun is a nightmare.
As has all ready been mentioned 30 psi cold is what you should have in your tires.
The inflation pressure of the tire is based on the size of the tire and weight of the car to determine the correct contact patch.
The reason that tires have a "max inflation pressure" on the sidewall is because tires can be fitted to a wide range of vehicles based on size. Some cars with additional weight will require more air pressure. The Corvette isn't one of them with stock or near stock sizes.
The TPMS sensors have a range of 24 psi low pressure to 42 psi high pressure. You will get a warning above or below those pressures. It can't be adjusted.
Tire pressure is not a set it and forget it item. Tire pressure will vary based on air temperature. Tire pressure will change approximately 1 psi for every 10 degree change in temperature. If the temp goes down, pressure goes down. If the temp goes up, the pressure goes up accordingly. Tire pressure will also increase as the tires heat up while driving.
For your pressure, unless you have radically departed from the OEM tire size you need to follow the manufacturers recommended inflation pressure that is posted on the side of the drivers door.
