Rocks in Panel Gap
Rocks in Panel Gap
Read the FAQ about the rocks in the panel gap between the rocker panel and the rear quarter panel in front of the rear tire. From the wheel side I stuffed in foam between the wheel liner and the quarter panel per the FAQ's.
Still getting rocks stuck in the gap. Are they coming from the brake duct? How can I close this off? Apsis front splash guards are on the car.
Any one else have this minor but annoying problem?
2010 GS.
2010 GS.
I get small rocks in the same location on my 2010 GS Coupe, and I also have the Apsis front splash guards installed. Seems to be much worse on the left hand/driver's side. I've not yet attempted to install the foam between rear wheel liner and quarter panel. I've been periodically removing screws and pulling the panel out to remove the rocks, but would love a permanent solution to this problem as well.
I did
I did get rocks stuck in there till I pulled my wheel liners out of the way and used duct tape on the back side to keep the rocks out. Problem solved.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
The gravel actually is flung by the front of the rear tire into that gap.
Drivers side worse,did the foam weather strip,didn't help much. Inner fender gap too large,thinking of just running a bead of black silicone.
http://forums.corvetteforum.com/c6-c...er-stones.html
Used some foam in the larger openings and then covered the lip of the fender liner from the 12 o'clock position down to the bottom of the liner in the front with black silicone sealant. Used nearly an entire large tube of it but with it being black and inside the fender lip, you can not see it. It is on my 2011 GS and there has not been one rock in either side since. Of course, you will need to remove the wheels for access with a
the caulk gun.
the caulk gun.
the caulk gun.
the caulk gun.
Ya know I put some weather strip in there a few years back, bout time I checked to see how it's doing. If need be I may try this stuff next. Mcmaster-car.
[IMG][/IMG]
[IMG][/IMG]
