Need tips on winter storage...moving to Syracuse
6th Gear
I am moving from Dallas to Syracuse NY and I was wondering how you folks that live in areas of BIG snow, store their vette for winter. I will garage it, but I am wondering what I need to do to take car of tires. if I just back it out once a week will that prevent any damage like flat spots.
Also, if anyone reads this from NY, how tough are they on front plate requirement? I don't run them here in Dallas and have had zero hassle except state troopers (2 warnings)
Mike
Mike
Mike
Mike
I've live up north and moved to Geogia. If you have to move, sell the vette, buy an old rusted out 4wd truck, a used snow blower, and save the rest for the increased taxes you'll have to pay.
"Dont' move" is good advice but if you must...you must. My understanding on the tires is if you have run-flats then flat spots are a relic of the past. Simply add 4 lbs of air to each tire.
As for the rest of the car, oil change + wash/wax + several small perforated plastic bags filled with mothballs to keep criters out + a highly rated, breathable car cover + a battery tender = good winter protection.
Works in New Hampshire.
4 lbs extra air
Race Car Tech
Same as above. Tire pressure raised to 38-40. Trickle charger.
Rather than moth *****, use dryer cling free sheets like bounce.
They smell better than moth ***** and do the same job...keeping varmits away.
If there is any chance of mice etc getting in the garage. Stuff socks in the exhaust tips, just so they wont nest in there.
Increase tire pressure.
Oil change in fall.
Park in garage on mats( moister barrier from concrete floor)
Wax car, clean inside, heavy on the leather cleaner.
Windows up.
Connect trickle charger, I don't keep it on 24/7 just couple times a week( I keep battery
connected).
Put car cover on.
This is what I do. No Sta bill, because storage is not long term. Just a few months.
Oil change in fall.
Windows up.
connected).
Put car cover on.
I have never run without front plates, but I've heard from others that you'll probably get pulled over without them. Seems like cops are looking for new ways to "raise revenue" as the politicians call it!
You will have fun driving in Upstate NY. Lots of hills and valleys! I'm from that area originally and it's definitely more scenic than Western NY where I live now.
Pump up tire pressure to 35 psi
Full tank of gas
Hook up Battery Tender
Cover it up
Wait until Spring and fire her up.
As for front plate enforcement been without front plate over 3 years no problems. (yet).
No need to start car during storage, no need to move it or worry about flat spots on the tires.
Full tank of gas
Cover it up
Received 8,928 Likes
Syracuse is about 70 miles North of me and has harder winters (more snow). I leave the tire pressure at the recommended 30, do my once per year oil change in late November or early Dec and wash the car (although that is a brisk task at that time of year) and put the it in the garage. There is almost always one day per month where the roads are clear enough to go out for a drive. By the way, Driving is the best way to store a car. I usually put 35 to 40 miles on the car when I take it out. As long as the road is dry I take it out. The road could be dusty from the snow removal materials that NY uses or it could have some icy spots on very cold nights but I still take mine out and enjoy it. It does a great job of removing the winter blues. If below freezing washing the car isn't an option but I don't let that worry me since it is only dust. Last year was the hardest winter we have had in a long time and I got to drive the car several times per month. Winter is basically from the end of November to the beginning of March with some snows thrown in from the beginning of November to the beginning of April. I can usually drive the car most of November and most of March.
Even if you don't drive the car tire flat spotting isn't a big issue. The old Nylon Tires of the 60s would flat spot over night but the flat spots would be gone in a few miles the next day. I haven't had any tires since then that flat spotted.
As for the front plate the fine used to be $50 but it may have gone up. On top of the fine there is an $85 surcharge and they will stop you for not having the front plate. NY State has a very tight budget and got even tighter after Hurricane Irene and Tropical Storm Lee which did far more damage than Irene. It is an easy $135 in the till for the state and it gives them an excuse to stop you and check for other violations that can run up the bill. I got stopped last year and always have a front plate on now.
Bill
Bill
OMG did you go to syracuse before you reached this decision? Did you go in January before you reached this decision. best advice you will ever get is DON"T GO!!!! from all so many perspectives.
I do not go thru toll booths often with the Vette but when I do I do not use the EZ pass, stop pay the toll and so far all is good.
Mike
Mike
Tom
If you use StaBil, and you should, be sure to add to a FULL tank and then drive it for a few miles to be sure the fuel has worked its way throughout the system, before putting it to bed. I would NOT use mothballs unless you really like the odor!
