Harmonic Balancer replacement
Old 10-07-2011, 03:12 PM
carllangford
carllangford's Avatar
Originally Posted by AJRace
I hope it is a tensioner or pulley bearing, but there sure is quite a bit of wobble there.....more than I'm comfy with lol. Engine feels good and smooth while accelerating and cruising, but I don't like that wobble and then when it was raining hearing the birds under the hood. I should find out tomorrow. Thanks y'all for your responses.
Any results?
Old 10-07-2011, 04:18 PM
Ghost 23
Ghost 23's Avatar
Originally Posted by Wayne O
I'd love to know why they changed.
The keyway and pin must have cost them at least ten cents per vehicle.
Old 06-07-2014, 02:45 PM
Billyac
Billyac's Avatar
Default I think I'm having this problem
This might be a crazy question Can I buy the bolt And just have that Swamped out And how do I know definitely I need a balancer
Old 05-04-2016, 02:31 PM
Corvette-2006
4th Gear
Corvette-2006's Avatar
Default Defective Harmonic Balancer
I'm thinking about contacting a Lawyer to start a CLASS ACTION SUITE, how many of you would be interested in getting in on it?
It's BS that these are not covered as a RECALL!!
Old 05-04-2016, 02:39 PM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
Making money for a lawyer is not a priority for me and that is all that will happen here. I installed an ATI and moved on.
Old 05-04-2016, 02:42 PM
cclive
cclive's Avatar
If you don't need a new balancer then by definition, you don't need a new bolt. The bolt is not the weak point, it's the balancer itself.
Old 05-04-2016, 02:45 PM
cclive
cclive's Avatar
Originally Posted by REVAK
I think it's ironic that my 98 LS1 and my 01 LS1 balancers are fine. My 06 LS2 balancer appears to be approaching the "wobble zone" @32k miles.
Even more so that my 42 year old Trans Am has a balancer that is just fine...
Old 05-04-2016, 03:51 PM
Sanya Kim
Sanya Kim's Avatar
I bought my car couple months ago and had to replaced the HB right away.
from what I read, dealers are going to want to charge more than $1k for this...
If I were you, I would not replace the HB with another GM HB. go with an aftermarket and don't worry about it any more.
Old 05-04-2016, 04:06 PM
_05C6_
_05C6_'s Avatar
A recall is only issued if an item is deemed a safety concern, and several reported incidents of said failure have to be documented.
Sh!tty design doesn't qualify.
Old 05-04-2016, 08:39 PM
Corvette-2006
4th Gear
I put mine in shop today to get mine replaced. I went with ATI and ARP bolts.
But you have to admit, This should be a RECALL!!
Old 05-04-2016, 09:36 PM
HBsurfer
HBsurfer's Avatar
As far as I am concerned, recalls should be saved for safety items. Even if the balancer comes apart, nobody is going to get hurt unless they have the bad luck of having their head in the engine bay when it happens. GM clearly knows about this bad part and got away with it for the entire run of the C6. That is a bad deal. Is it dangerous, no. Complete failures have only been reported on here a couple of times in the last two years. A class action lawsuit for something like this is silly.
Old 05-05-2016, 05:32 AM
Corvette-2006
4th Gear
If the know it's a bad part, they should at least fix it for free.
A Lawsuit, OK maybe a little out there! But,I think everyone should stand behind their products they sell.
Old 05-05-2016, 11:55 AM
  #33
cclive
cclive's Avatar
What I don't understand is why GM is not screaming at the supplier that made the balancer.
Old 05-05-2016, 02:53 PM
  #34
windyC6
windyC6's Avatar
Originally Posted by Goatdad
In basic terms you need to remove the balancer and grind a key way into the crank.
This isn't necessary. You can pin the balancer while its mounted. Some of the after markets give you the kit when you buy their balancer. In a nut shell you drill a hole from the front where the balancer and crank meet. They give you a guide to be sure you drill straight...etc. So you are actually drilling a small 1/2 round hole in each the crank and the balancer. Pound/press in the pin and your good to go....
Old 05-05-2016, 06:03 PM
  #35
Corvette-2006
4th Gear
That's not the point! You buy a $50k car and by the time you have 60k miles on it,you have to drop over $1000 into it for a faulty part!! One guy said his went out at 1,000 miles! Warranty covered that one. I has ASC Warranty on mine,but they just call it a PULLEY and won't cover it!!
Old 05-06-2016, 10:47 AM
  #36
windyC6
windyC6's Avatar
You'll get no argument from me on that. I was just responding to a post. I've been a big advocate on the fact that the balancer going south is a big no-no from GM. I've kinda learned to just accpet it cause I don't think there is a darn thing they are going to/will do about it. What I find disturbing is some of the post left in previous threads on the subject....anywhere from...."oh....parts break so just get it fixed"....to the really lame one of..."Oh, there aren't that many of them going bad so what is everyone complaining about".....
Old 05-06-2016, 01:37 PM
  #37
Not So Fast
Not So Fast's Avatar
You can count on me Let us know please
Makes me sick thinking that mine will have to be replaced in the future because it has a slight wobble now. Really disappointing
NSF
To Harmonic Balancer replacement
Old 05-06-2016, 01:43 PM
  #38
Usafhaynes1
Usafhaynes1's Avatar
Just bought a 2005 C6 yesterday. It's in the shop today for the HB wobble issue. Luckily the used car dealer i purchased it from is offering to cover 50% of the parts/labor!
Old 05-06-2016, 02:19 PM
  #39
windyC6
windyC6's Avatar
Well that doesn't sound like a bad deal at all. Good to hear that there are some reputable pre-owned dealers out there.
Old 05-06-2016, 02:39 PM
  #40
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Was this solely a problem with the LS2 or where LS3's affected too?
Quick Reply: Harmonic Balancer replacement
