Where can you buy cross beam adapters?
I just checked NorthernTool.com and they no longer sell the the cross beam adapters that several members use to lift their C6--anyone know where else I can puchase these?
I used a 2 x 6 to span the jacking points. At the jacking points I nailed another short pad length 2 x 6 on the ends. Made one for the front and one for the rear.
Along with ramps, this design was posted in the C5 section.
Received 2,225 Likes
Location: Somewhere you've probably never heard of in New Mexico
St. Jude Donor '11-'13-'14-'15
I bought a set on a certain auction site. I'll have to modify them to fit in my jack tho.
CF Senior Member
Here's the link to the Summit Racing crossbeam adaptor:
http://www.summitracing.com/parts/SUM-918008/
It appears to virtually identical to what Northern Tool used to sell.
1 Post
Received 1,072 Likes
2015 C7 of the Year Finalist
Received 2,051 Likes
St. Jude Donor '13
How does yours look when you life the car?
The overall length of the 2 x 6's are 26". On each end the additional pad is 6" long. The car lift points are about 20" apart. I made these for a C5 but they work on the C6. I tried a search to find the post that detailed the design - could not find it.
I drive the car on 2 thicknesses of 2 x 12's on all 4 wheels to clear the undercarriage when I slide the jack plus the board thicknesses under the car. Once the car is raised I place jack stands at the 4 rocker panel frame points using 2 x 4 pads as lift pucks. If I work directly under the car I slide in a couple of cement blocks as added safety.
The 2 x 6's do not deflect much, certainly not 1.5". Between my C6 and C5 I've lifted the cars about 6 times with no problems. If you are skeptical about the deflection you could use 2 x 8's.
I have wood properties at work. If I get the chance I can calculate the deflection.
Received 8,928 Likes
You don't need it and don't need the 2x4s. I have been jacking C5s and C6s many times per year for the last 14 years and have never needed that stuff. All it does is slow you down.
Bill
Bill
So how do you lift your cars because it is a pain getting it high enough to work under it. I would like a simpler method. I pulled the above off the forum several years ago.
St. Jude Donor '13
If it works, it works. I'll believe you that the deflection is minimal.
