Set parking brake properly....
Old 10-12-2011, 04:34 PM
  #41
jackhall99
Support Corvetteforum!
jackhall99's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Originally Posted by Racer
I am surprised this topic is even here, I learned how to use a parking brake even before I used to steal my parents car when I was 12.
Amen Tony. Some of these noobs know less than they think they know.
Old 10-12-2011, 04:57 PM
  #42
jackhall99
jackhall99's Avatar
Originally Posted by azschmeh
... I can't imagine not leaving it in gear when parked...of course, I grew up driving MG's, so I was used to having a backup in case of mechanical failure.
You too?
I did my internship in Healeys; same difference.
Old 10-12-2011, 04:59 PM
  #43
NJLS708
NJLS708's Avatar
Hopefully GM will go with the push button parking brake like the Audi's currently have on the C7.
Old 10-12-2011, 05:12 PM
  #44
LMB-Z
LMB-Z's Avatar
I thought that lever was the line lock for drag racing. Never used it before and probably never will (hopefully).
Thanks for the information.
Old 10-12-2011, 05:19 PM
  #45
TCW
TCW's Avatar
St. Jude Donor '06-13,'16-'17, '19
Originally Posted by Swiftrider08
You don't understand how the "parking brake" works on the C6. There is a small set of actual "brake shoes" inside the rear rotors that are the parking brake. The actual pads have no connection to the parking brake itself"
Correct answer! Give this man a cigar.
Tom
Old 10-12-2011, 05:23 PM
  #46
speedraider
speedraider's Avatar
Originally Posted by njls708
hopefully gm will go with the push button parking brake like the audi's currently have on the c7.
a 7
Old 10-12-2011, 06:21 PM
  #47
su8pack1
su8pack1's Avatar
I now use it all the time now as it cost me $4,400.00 because I didn't.
Old 10-12-2011, 07:56 PM
  #48
Dif
Dif's Avatar
I remember from when I was a kid how the Corvette E Brake never worked all that well because it was just small regular brake pads inside a small diameter brake drum.
Regardless of that, I have always set the parking brake when I park, out of habit.
1. simply because it's there and it holds the vehicle from moving. And in the case of a Corvette, it helps even if it does not totally hold it.
2. to keep the cable and pads from becoming frozen from not being used.
As far as what the Owners Manual says, I never read it until this thread.
But, I always step on the brake pedal with the vehicle in Neutral before applying the E Brake and then put the vehicle in Park or in gear afterwards.
My reason for doing that is so the gears in the transmission, whether a Manual or Auto, are not supporting the weight of the vehicle.
When ready to drive the vehicle, I don't release the E Brake until the vehicle is running and in gear ready to drive off.
Anyway, just some info and take it for what it's worth
Old 10-12-2011, 09:02 PM
  #49
NJLS708
NJLS708's Avatar
Originally Posted by speedraider
a 7
I meant C7 as in the next Corvette, sorry for not being more clear.
Old 10-12-2011, 11:48 PM
  #50
Dale1990
Dale1990's Avatar
St. Jude Donor '15
I always use the parking brake on the C6 just so the exit mode on the power seats work; I have a narrow garage and narrow parking spaces at work. I also leave it in gear since I don't really trust the brake.
Just for fun I tried to use the parking brake to slow the car at speed and I barely felt it slow down. I've driven cars where a brake hose burst dumping most of the fluid (front line, shared reservoir) and I could still stop far better. I would not depend on it for anything.
Old 10-13-2011, 02:08 AM
  #51
AtHomeSoda
AtHomeSoda's Avatar
Default Well...
My C3 and C5 (never had a C4) and my C6 has all been the same for the E Brake... OLD TIME Shoes, INSIDE the Rotor... and Yes I have Pulled up on the E brake, hold the button in, and YES it will slow you down...It is really only ment to hold when you are stopped, but it is Shoes in a Drum... so the harder you PULL the more it stops.
Old 10-13-2011, 08:00 AM
  #52
davekp78
davekp78's Avatar
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by Kevin_NYC
Put in reverse if on down incline
Put in 1st if on up incline
Also turn wheels to toward curb, if near
No. Just the opposite. You want the car to work against the compression of the cylinders.
Old 10-13-2011, 08:35 AM
  #53
redzone
redzone's Avatar
Are you actually saying the motor turns a different way depending on whether you're going forward or reverse?
Old 10-13-2011, 09:46 AM
  #54
haljensen
haljensen's Avatar
Only on my 1956 80HP Mercury outboard motor and a few other 2stroke motors..
No gears, no neutral, the engine starts and turns one way for forward and rotates the opposite direction for reverse.
Got to love 2 strokes. No cams, no valves and will run in whatever rotation you start them.
Old 10-13-2011, 10:08 AM
  #55
Triumph Jerry
Triumph Jerry's Avatar
Hahahahahahaah!!! What he said!!
Old 10-13-2011, 10:12 AM
  #56
Triumph Jerry
The reason car manufacturers suggest leaving standard transmissions in
reverse, is because it's the lowest gear.
Old 10-13-2011, 10:32 AM
  #57
Kevin_NYC
Kevin_NYC's Avatar
I get the compression / lowest gear bit
But, how is a car going to roll backward in 1st gear or fwd in reverse?
To Set parking brake properly....
Old 10-13-2011, 10:57 AM
  #58
toomanydogshere
toomanydogshere's Avatar
Using the lever alone a woman would not get enough pressure to
hold the car.
Old 10-13-2011, 11:07 AM
  #59
Speedforhire
Speedforhire's Avatar
Gotta agree with the O.P..........the other day I was rushing it and forgot to apply pedal pressure and my car rolled forward about 5 inches once I opened the door........it almost wreaked havoc on my front fascia.......got a small, white paint smudge (which buffed out) from contacting the garage door.
Old 10-13-2011, 06:22 PM
  #60
haljensen
haljensen's Avatar
Because the engine ALWAYS rotates in the same direction.
Quick Reply: Set parking brake properly....
