Old 03-02-2015, 08:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Throttle Position Sensor
Old 10-18-2011, 02:30 PM
carmos
carmos's Avatar
Default Throttle Position Sensor
hi all, does anyone know who sells the Throttle Position Sensor by it self called the dealer i normally use here in cali selman chevy and was told u have to buy the whole throttle body to get the sensor for 500 plus bucks checked a few of the online vendors and cant seem to find the part anywhere..thanks for any help.my vette is a 2008 c6 auto.
Old 10-18-2011, 08:11 PM
chimazo
chimazo's Avatar
99% sure your dealer is correct that the TPS is not separately available and that you must purchase a new throttle body assembly.
I believe that the p/n is 12570790 and you can find it new online for around $300.
Old 10-19-2011, 11:25 AM
TTZ06VETTE
TTZ06VETTE's Avatar
That's the way I understand it as well
Old 10-19-2011, 11:36 AM
Kenny94945
Kenny94945's Avatar
Try a used part for cost savings?
Old 10-20-2011, 12:43 PM
carmos
carmos's Avatar
thanks for all the help guys
Old 10-20-2011, 06:01 PM
ALS 08
ALS 08's Avatar
Drive by wire.
Most automobiles use a throttle position sensor (TPS) to provide input to traction control, antilock brakes, fuel injection, and other systems, but use a cable to directly connect the pedal with the throttle.
An Electronic throttle control (ETC)-equipped vehicle has no such cable. Instead, the electronic control unit (ECU) determines the required throttle position by calculations from data measured by other sensors such as an accelerator pedal position sensor, engine speed sensor, vehicle speed sensor etc.
The absence of any mechanical linkage between the throttle pedal and the throttle body necessitates the use of a servomotor.
Integral to the servomotor (in this particular instance) is the TPS (Throttle Position Sensor).
Old 10-20-2011, 07:53 PM
sgrubbs
sgrubbs's Avatar
Default Question
Does your throttle stick in the vicinity if 1500 RPM when you push in your clutch - only to settle down after you stop. Mine does that from time to time. I have replaced the throttle body and the ECM in recent months - neither has fixed the issue. Solution seems to be alluding the techs.
Old 10-20-2011, 08:39 PM
Like dem Vettes
Like dem Vettes's Avatar
You don't necessarily need to replace the TPS. Did you test the TPS? A shop manual will provide the reference voltages. Here is something from You Tube on testing: http://www.youtube.com/watch?v=6eoH4...eature=related
Old 10-20-2011, 08:50 PM
fnsblum
fnsblum's Avatar
I would think that part is still under the engine or emissions warranty. Later! Frank
Old 10-22-2011, 09:56 AM
chimazo
chimazo's Avatar
A hanging throttle is almost certainly a tuning issue, typically the dashpot function.
To Throttle Position Sensor
Quick Reply: Throttle Position Sensor
