Do you torque your oil pan bolt?
Old 12-07-2011, 10:31 AM
Jimmy W1
Jimmy W1's Avatar
Default Do you torque your oil pan bolt?
On your C6, after you drain the oil, and you put the plug back in the oil pan, do you use a torque wrench to tighten down the bolt? How many foot pounds do you torque it to? Or, how many foot pounds are you supposed to torque it to? Thanks.
Old 12-07-2011, 10:35 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Never have on any of my vehicles, I just tighten it, never had problems.
Old 12-07-2011, 10:42 AM
weathermaker
weathermaker's Avatar
Just get it tight enough so it will not back out. You don't have to put a 2' wrench on it and push 'till your nose bleeds.
Old 12-07-2011, 10:48 AM
Cypher
Cypher's Avatar
I do...Spec is 18 ft lbs if I recall.
Old 12-07-2011, 10:52 AM
CENT Z06
CENT Z06's Avatar
I usually just hand tighten it and then snug it a little more if needed.
According to this guide in the FAQ it's 18lb/ft.
http://www.davidfarmerstuff.com/C6-Torque-Manual.PDF
FloydSummerOf68
FloydSummerOf68's Avatar
I just tighten it up until it's snug....I've never even thought about torquing it down to a spec.
Old 12-07-2011, 10:54 AM
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
Nope.
Old 12-07-2011, 10:56 AM
Kenny94945
Kenny94945's Avatar
Yes....LS2...18 ft lbs...alway use new seal too.
Old 12-07-2011, 10:57 AM
Cypher
Cypher's Avatar
Hey, I recall pretty good…that’s a lot of work these days.
Old 12-07-2011, 11:30 AM
Larry/car
Larry/car's Avatar
I'm bad. I just tighten the plug and reuse the old seal. When I get to this point in the oil change procedure, I am home free. That is after I dump six plus quarts of used oil on the floor. I have spilled more oil than anyone else on the forum.
CENT Z06
CENT Z06's Avatar
Pretty Darn Good.
Old 12-07-2011, 11:31 AM
Glennm27
Glennm27's Avatar
Received 1,407 Likes on 611 Posts
2017 C7 of the Year Finalist
St. Jude Contributor
No .
Old 12-07-2011, 11:45 AM
7795TAs
7795TAs's Avatar
I just snug it up. Never had a problem.
Old 12-07-2011, 11:58 AM
torquetube
torquetube's Avatar
Those seals last a long time. I replaced mine after about 15 oil changes just because, but it was still in good shape.
Old 12-07-2011, 12:08 PM
j_digi454
j_digi454's Avatar
I might be a close second.
Old 12-07-2011, 12:10 PM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
I did once just to calibrate my arm. 18'# quoted above is correct. Best description is it is just snug. That's a steel plug in an aluminum pan. Get it at all snug and it isn't going to back out. You are far more likely to damage it by getting it too tight.
Old 12-07-2011, 12:11 PM
FloydSummerOf68
You're supposed to replace those seals?
Haven't done that on the past 7 cars I've owned either
To Do you torque your oil pan bolt?
Old 12-07-2011, 06:51 PM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
Just snug it up good. 18 Ft lbs is not very much at all.
Old 12-07-2011, 06:58 PM
John in MD
John in MD's Avatar
I always use a torque wrench. I'm afraid of stripping out the threads in the aluminum oil pan.
John
Old 12-07-2011, 07:02 PM
RICH 28
RICH 28's Avatar
I didn't know you were supposed to replace the seals either.
Quick Reply: Do you torque your oil pan bolt?
