C6 Seat Rebuild Kits @ JWM
#41
I found some high density foam at a furniture shop and though I could just put more foam in with JW's rebuilt kit but when I got into it the additional foam would not work. Just get the rebuild kit and it will make a huge difference. The jute pad is a must it stops the form from getting cut into by the springs. This kit makes a huge difference.
#44
Both of my outside bolters (driver and passenger) are flat and showing wrinkles, thinking of getting your repair kit. If I do need to replace original foam, do you also provide that?
#47
1 Post
JW, thanks for the referral. I keep the complete foam kits in stock. Shoot me an email or give me a call. I can supply you so you have a complete kit, or maybe we do a joint sale?
Kevin
www.PartsTaxi.com
Bump for a great vendor!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kevin
www.PartsTaxi.com
Do you have any of the kits in stock?
#49
The center section sagged so much, it pinched my hips something awful. I was in pain after only 15 minutes. I thought, what the he!! is the matter with the seat?
Then I did some research here on the forum and saw a lot of guys had installed the kit and it fixed not only the sagging in the middle, but also returned the outside bolsters to their originally position. When I pulled the seat apart, I was shocked when I removed the foam and saw how torn up the bolster was. The center wires had sliced into the foam and bolster foam has nothing to support it from below. The bolster was torn where it sat on the seat frame. What a terrible design by GM/Lear! There is a big gap between the seat frame and the center support wires.
Everytime I take a trip in my car, I thank the guy who came up with the kit. Brilliant idea and cheap, too.
#51
The stitching was coming loose on my driver seat buttom at only 2000 miles. I took the seat off and took it to the dealer (I did not want them stratching the door panels and sills) and the replacement after the fact looked horrible. They said it will fill in with time. Yeah, right!. It was loose ill fitting and flat. I played around with it for few hours and brought it to almost 80% but still not happy with it. I hope this kit will fill it out a bit so I am going to take a chance and order one right now.
#52
So another POS design that would have cost $0.50 for GM to fix. And not even fixed it on 2012s? Geez; unbelievable. Anyway, own a '12 GS here with the alcantara inserts (3K miles so far), and was wondering if this issue is more prevalent with heavier folks. I'm only 160#, and the CE doesn't have any leather (at least all bolsters are vinyl, which might be actually good, since Vette's leather is crap anyway), meaning vinyl deforms less. I don't want to tear my new car apart now, but already bookmarked this thread since I use my seat all the way down, and feels somewhat hard. I'm afraid the seat bottom won't look like factory once I mess with it. Just like GSflyer, I had another car's seat cushion taken apart due to a malfunctioning airbag sensor, and looked like crap afterwards, even after summoning a professional upholstery shop. Seems like the Vette seat cushion is easier to deal with. Have a good one.
#53
1 Post
Don't think weight has anything to do with it. I weigh 170lbs and my seat looks like the damn invisible man is sitting in it. I've driven it once in the past 3 weeks because it so uncomfortable. I just need to find out how much of a pain it will be to deal with the heat seater pad once the seat is taken apart.
#54
I ordered the parts to fix my seat (hope to get to it this week) a few weeks ago.
The detailed instructions with photos are included with the kit and once you start the project you see how it goes comes apart. Pretty straight forward. Some of the best instructions I've ever seen. Nothing to be scared about.
All the C6 seats from 2005- 2013 are the same except there is a little more foam on the bolsters on the 2013 seats. They did not address the center wires cutting the foam nor the lack of support under the bolsters. They look nicer...and they are...but the support structure is the same. Eventually, the bolsters foam will tear and the bolsters will flatten out. And the center area will droop and look baggy.
#55
Seat removal & disassembly video:
http://www.youtube.com/watch?feature...&v=oF7ZpMP_4CQ
The most difficult part for me was removing the recline lever. Some tips:
http://forums.corvetteforum.com/c5-p...r-removal.html
#56
My car has only 17000 miles on it. I just did the repair this afternoon. The side foam gets cut on the seat frame due to no support under the side bolster. The bottom gets cut by the wire support grid under the seat. I used the nylon on the foam, and the jute over the wire grid. I did add some 1/2" foam to the outside of my bolster to help fill out the wrinkles in the cover. Took me about an hour. Seat looks and feels great!
10 days now...still waiting for the new seat cushion, the cover and the heat pad from the dealer under warranty....
#57
Was surprised to see that the leatherseats.com video didn't address the problem this thread is all about. Have a few installation questions:
- Has anybody done this to his 2012 seats yet? Don't want to deal with replacing the foam, so thinking of doing this as a preventive measure, now that I have a little over 3K miles.
- With no damaged foam (or very little), I was thinking of just attaching the jute to the frame and call it a day. Or is the nylon needed too? If so, it can also be attached under the jute, right? Don't want to mess with gluing anything, nor do I feel there's a need for that. Plus if we want the springs not to damage the jute over time as well, the nylon has to go at the very bottom IMO. Comments welcome.
- Is there a need to add any foam to the 2012 seats? Besides being relatively light (160#), I always lever myself in and out of the seats, so I won't wear the bolsters down over time. And I don't want them any firmer than they already are, since they're borderline uncomfortable against my left thigh when my foot rests on the dead pedal.
- Is there a better way to remove the reclining lever than what the video shows yanking on the lever outward to push the clip down? Somebody mentioned a 'crochet' needle (I have a pick slimmer than that), but how the heck do you pull the clip since you'd have to turn the pick to grab the clip? We'd probably break the thin plastic next to the slot to slide the clip, no? Clip is rather close, so no space to pull it before the pick touches the plastic.
- Is there an easier way to pull the yellow connector that the guy in the video pushes the seat against the seat console to remove it? I'd prefer not to recline the seat against the console at all if possible.
- Finally, can zip ties apply the same pressure as those 'hog rings'? Maybe that's why the cushions don't look factory after reinstallation???
Thanks gang.
Thanks gang.
#58
Thanks gang.
Thanks gang.
4-Removing the reclining lever is not that hard, hold a flashlight to the slit, you will see the one edge of the retaining clip (on either side) and push that out with a very thin bladed instrument (I used a thin stake knife with a sharp point..) to pop the clip off. You do have to wiggle the handle as it is a tight fit. But comes off with no damage.
5-Make sure you first put the seat all the way up before taking out the bolts. Still there is no room under there to remove the connectors without pulling the seat off the bolts and tilting it towards the console as much as you need to but it does not damage the console as the side of the seat is heavily bolstered. I have now removed the driver seat 2 times, I do not even have to take the roof off for it. Make sure you protect the door sill and the plastic trim around the carpets with lot of towels or an big old thick comforter in my case.
6-In my humble opinion, the zip ties apply better pressure as you can make them tighter and more secure. With Hog rings there is always going to be some slack. Also zip ties will not cut/chew into the material or the foam like the rings. Thicker material and more surface contact area and less movement. The ones supplied with the kit and what I like using is the 8 inch double lock cable zip ties. Nice and strong.
I also just removed the airbag fuse, not the battery cable, but one must wait at least 60 seconds after either method as the bags are designed to retain power for that long in the case of an accident.
Good luck JC!
#59
In post # 98 that video clearly shows them adding the jute pad towards the end... I'm gonna order up a couple of sets but won't do it till the spring time... To cold to freeze my a$$ off so they'll stay until then.. I also have to order some a new seat bottom and middle seat back as I got them really dirty from doing work at my sons house the last 9 months... Anyone ever buy them from GM??
thanks,
/jc
thanks,
/jc
Thanks gang.
Thanks gang.
#60
