Dealer wants $110 to flash ECM
You just need to get your priorities straight.
GM has a TIS website that shows all of the available firmware updates in it for each specific VIN#. I've seen a lot of dealers lately offering free PCM/ECU updates in conjuction with a routine service visit. The usual charge is one hour of labor to do it at the going labor rate. http://tis2web.service.gm.com/tis2web
GM Vehicle Calibration Information
VIN: ?????????????976
Controller: PCM/VCM Powertrain/Vehicle Control Module
Calibration History for: Main Operating System
Part Number CVN Bulletin # Description
12613186 0000CF0F - New software to address potential battery run-down situation.
12605740 00002555 - New software with diagnostic enhancements for DTC P0463 and P2068. Replaces all previous software.
Calibration History for: System
12599005 00009447 - New calibration with diagnostic enhancements for DTC U0001
12596519 0000EBF7 - New calibration to address A/C compressor clutch failure due to clutch re-engagement at high RPM
12595747 00006BCD - New calibration to reduce the potential for setting DTC P0604
12594724 000019AB - System calibration
Calibration History for: Fuel system
12605744 000040DC - New calibration with diagnostic enhancements for DTC P0463 and P2068.
12595745 0000527E - New calibration to reduce the potential for setting DTC P0604
12592710 000036F9 - Fuel system calibration
Calibration History for: Speedometer
12595751 0000796F - New calibration to reduce the potential for setting DTC P0604
12594728 00001598 - Speedometer calibration
Calibration History for: Engine diagnostic
12618497 0000CF65 - New calibration with diagnostic enhancements for DTC P0449.
12613312 0000C01E - New calibration with diagnostic enhancements for DTC P0833.
12605743 0000E146 - New calibration with diagnostic enhancements for DTC P0463 and P2068.
12599003 00001202 - New calibration with diagnostic enhancements for DTC U0001
12597190 000075AC - New calibration to reduce the potential for setting DTC P0336.
12596517 0000A3B4 - New calibration to reduce the potential for setting P0507 and P0443.
12595744 0000808A - New calibration to reduce the potential for setting DTC P0604
12594722 000083F0 - Engine diagnostic calibration
Calibration History for: Engine Operation
12597183 0000E810 - New calibration to reduce the potential for setting DTC P0336.
12595736 0000E97F - New calibration to reduce the potential for setting DTC P0604
12594714 0000A5D1 - Engine Operation
Calibration History for: Slave Operating System
12596661 0000367D - New calibration to correct problem occuring at the assembly plant. Does not address any service issues.
12595727 0000D1B0 - New software to reduce the potential for setting DTC P0604.
12594729 0000E297 - Slave Operating System
12595737 00007A5E - New calibration to reduce the potential for setting DTC P0604
12594715 000034CD - Engine calibration
Wounded Warrior Escort '11
My pure guess would be all of them. Our cars are like computers with wheels. We regulary update our home computers with updated software, security enhancments and repairs to the operating systems where bugs were found and corrected. Why should our cars be any different? I would discuss these with a competent tech at the dealer and have them call the GM Tech Center to inquire about them in regards to your car.
Jessus where will it end - next thing they will want to charge us for oil changes, tire repairs & other repairs also= oh God the horror
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
If you have VERY early software....
I have a 2005 C6 and I want to know if it is worth the $110 to get the PCM/ECM fixed? I am hoping this fixes the shifter in reverse battery drain issue and the antenna booster issue (am to fm to make it work).
I am way out of warranty and this is not a recall, so comments?
Of course, there could be several other reasons for it....
In 2005 I believe there are at least 6 different versions of the software for your 2005
Corvette. It was a first year for the car and there were issues to be remedied.
Check to see if your reverse lights work cause if they don't the battery will die when you park it....
I can also do the software for you as well...
Chuck CoW
