DIY: Tinted Side Markers
I bought some Night shade today and decided to tint out my side markers as i hate them as is
Whole thing Cost me about $12 and that is including the tail lights il be doing tomorrow
. Just a quick DIY for y'all.
As i did this i really didn't think about making it a write up but figured i would after so excuse the no pictures aspect.
**Tomorrow i will be Editing this with the update of how to Remove and Tint the Tail Lights and Third Brake Light **
1. I bought the VHT Nightshade from auto Zone along with 2000 Grit Wet/Dry Sand paper.
2. Remove the Side markers.
Front: Turn your wheels all the way one way or another depending on witch side your taking out. Example> if your taking the Drivers side marker out turn the wheel all the way towards the passenger side to access the Plastic guard that covers the inside of the front bumper. Remove the 5 Star head screws holding the Cover in place. Then pull the cover as far back as you can to squeeze your hand in and the pop out the retaining clips that hold the Side Marker in. There will be two clips per marker. Once seen it makes the process a lot easier but just know theres two and kinda fidget with what you can feel until the pop out on the first one.
Rear: Remove the furthermost left and right tail lights. To do so use the same Star head screw driver you used to remove the Covers in the front. Theres a Screw at the 12 O'clock position of each tail light facing up. Just remove the bolt and the tail light will slide right out.
( great time to tint the tail lights if your going to )
Once out reach into the open tail light towards where you think the side marker is located and once you feel it pop out the same two retaining clips like you did in the front. Also once the side markers are out twist the light assembly of each one to remove the bulb and separate you marker from the actually wiring harness.
3. Using the 2000 Grit Sand paper wet sand the side markers until there looking sorta hazy. I just put some dish soap in a cup of water, mixed it together and then dipped my sand paper in it every so often while sanding. After your finished Dry them off and they should look a little hazy or fogged. this is good.
4. use Alchol and wipe down the side markers to remove any oils or finger prints or other unwanted debris.
5. Tint the Side Marker.
I used the VHT NightShade but any sparyable tint will work, do very light even coats. Wait 5 Mins between coats depending on your temp and humidity. 2 coats should give you a smoked look if your spraying them correctly. 3 will be more blacked out. Being there side markers i did 3 as i don't care how bright they are when lit.
6. Clear Coat
Any clear coat will work, i used Duplicolor high gloss Automotive clear coat. Wait 10-15 Mins before applying the Clear to the lights after finishing your last coat of Tint. and again 5 Minutes between coats of clear. I did 3 coats starting with a very light 1st coat as always. Let this coat dry at least 1-2 Hours before Proceeding to step 7.
* if you want a high gloss factory look follow the steps below, if your satisfied with the look then ignore steps 7-8. Or if you want a flat look then get a flat clear coat and be done.
7. Wet Sand ( again )
Using the same 2000 Grit sand paper and the wet sanding solution you made earlier. ( soap and water ) very lightly wet sand the Side Markers. * Important ! only wet sand in one direction not circles or back and forth. Start from the left to right and then lift the sand paper back to the left and repeat.* You again want to get them a hazy look, but do not want to strip off the tint so be very careful.
8. Polish
apply Rubbing compound to the lights surface and rub the SH!& out of it, make sure you get the whole thing rubbed down and throughly. Once your finished. wipe it down with a microfiber cloth. If the shine/Glossy look is what you want go ahead and put a coat of wax on it. if not repeat with the rubbing compound.
9. Reinstall the Lights
Easy enough, re installation just requires putting the bulbs back into the markers and locking them into place and then pushing them back into their place.
10. Stand back and Enjoy
And here there on around 5pm
Please Excuse my car being so dirty, and the Z06 Emblems are getting painted Black/Red right now and thats why their off the car
As i said I'm sorry about the pictures not step by step, i think i covered just about anything i just didn't think to take pictures throughout the process. Il be doing my Tail lights tomorrow as i didn't have enough time today. If you have any questions feel free to ask.
6. Clear Coat
8. Polish
Thank You !
Just wait another month, ZR1 body kit in all black, Black Headlights, and EXO Mesh 8 Concave Wheels in all Matte/Gloss Black. My Main Concern right now are the holes in my Fenders from no Z06 Emblems at the Moment Looks terrible
No problem, my tail lights I'm going more of a smoked, only reason I went so dark is because there side markers. I could care less if they light up or not lol. Plus with the black accents the dark side markers will pop more
Did the very same thing to mine. So easy. I sanded the factory lettering off my markers before I painted them. I love the look. I will not do my tail lights. I want all the light I can get, here in Cal. traffic. Red tail and brake lights do not bother me.
Thanks for the write up. It couldn't be much easier or inexpensive to do.
I also did my GS Badge with the same VTH paint. Then I sanded them with 1500 grit to take the shine off. Repainted the G and the S in Royal Blue rather than Red. Everyone do your own thing. Have fun. Don't be scared to make it your own..
There are several videos on YouTube on how to do this as well. Just type in Nite Shades. I watched the videos a couple of times and followed the instructions when I tinted my new SMD side markers recently. Basically it's the same instructions as the OP.
Jabls7, quick question. I smoked my lens just like you instructed and they came out almost perfect. On one of the sidemarkers, I guess i didnt spray enough night shade on it and when I went to wetsand, it took off too much. Can I use paint thinner to remove the nightshade and clear coat to try it again? I may just send them off to get them done by a pro, as I could not get them glossy enough after wet sanding and polishing.
Anyone know how I would remove the nightshade and clear coat?
Bumping an old thread I know. Just noticed this thread has the picture from this site. I guess they're using your nightshade picture to sell their overpriced $200 tinted side markers. That's some bullshit.
https://www.corvettemods.com/C6-Corv...e-_p_6836.html
Looks like someone may be ripping your pics.....
https://www.corvettemods.com/C6-Corv...SABEgJXSvD_BwE
