Any experience with the new Michelin Pilot Super Sport tires?
My 2011 GS Coupe with manual trans. and F55 has 16,000 miles and needs new rubber. I've been looking, reading, and asking for advice all fall and winter in anticipation of making the best possible choice. I'm kinda leaning towards the new Michelin Pilot Super Sport for the following reasons:
1. 300 tread wear rating (UTQG for the purists) compared to 220
2. Lower price for set (about $500)
3. 30,000 mile warranty (I know it's less due to rotation issue)
These are "data" issues. There are other anecdotal reasons such as better handling and noise claims but I have no first or second hand knowledge of these. Hoping someone may even though they are quite new. I know they are not ZP (runflats) but I'm tired of 16,000 mile limitation when I may be able to get near performance for better mileage. Besides, I've never had a flat and hoping ONSTAR may provide the insurance I need just in case. Opinions vary but I'd like to hear them.
There have been a couple of owners that have the Super Sports, buy not long enough to give us anything but a couple of days evaluation. Other then longer life then the OE Goodyears, what other benefits are you expecting to gain with the Super Sports that the PS2 won't provide, or the much cheaper Bridgestones that have a 280 rating.
I've been thinking the same. My guy at my local discount tire has revived good feed back from the ones hes sold so far. I'll be deciding in March along with a set of CCW wheels.
I also would be interested in knowing about this also. I hate the Goodyears and when I was at Convention last year the guys from Bowling Green were there and asked how I liked my new GS. I told them great except the tires. An they responded that is the number 1 complaint. Also I did not know that the rear tire were out yet. Last time I checked they were not. An I didn't know they were $500 a set. I like that. Will follow this thread. Thanks for posting. Shannon
I had a set of them on my 2009 G8 GXP, they replaced the stock Bridgestone RE050a's that came on the car. I put about 500 miles on them before I sold the car.
They rode excellent, handling was great as well. They have a huge outside edge tread block on them, plus you cant beat that they have a 300 treadware rating. For the money they would be a great tire to consider if you are going the non-run flat route.
My brother replaced PS2's non run flats with the super sports on his turbo porsche. He loves them and said they are an improvement over the PS2's. The difference is not by a large margin, but he felt they are stickier.
As far as mileage, I have 30k miles on the ZP's, compare that to 16k on the G.Y. Supercars.
The Super Spoorts would be my choice for a non runflat tire.
If one(me) wishes to keep the run flat feature then the SS is $68 cheaper then the bridgestone RE050A run flat tire and the Bridgestone has a 280 tires rating vs the SS's 300. From the wear I have seen so far on my Bridgestones, I expect to see at least 25,000 miles from them. Quite an improvement over the Goodyear SuperCars with a 220 rating and a $1802 price tag.
PS- when I was looking at new tires for my Z06, I checked Tire Rack and DTD and then my local tire dealer. I got the Bridgestones for $1567 out the door(that includes taxes, mounting and balancing) in April, 2011. Beat the snot out of the mail order dealer's prices.
Don't compare tire wear ratings between brands. Bridgestone's 280 could be better than Michelin's 300 for example. Tire wear ratings are pretty much bogus. It doesn't take a rocket scientist to believe an A/S tire is better than a top performance tire (A/S ZP vs PS2 ZP). You are giving up a lot of grip for some additional miles.
I hope the Super Sport comes out with a ZP version for the GS/Z06. I'm not switching to run flat. Too many in the middle of no where places out here in Utah. The less chance of having a tire removed is better for me and my rims.
I'll even be buying a good air compressor and a can of goo just to keep me going if I need to. (which I would have needed last year if I was driving my Vette instead of my Denali, it took an old wheel weight into the left rear tread and I had to use the spare). No tire repair shop for 200 miles or so.
http://forums.corvetteforum.com/1580112657-post75.html
Cliffs: Michelin PSS tires in stock sizes will let you nail it off the line with a one to two foot rollout and stick like glue at full throttle all the way through 2nd in 45 degrees F. NO lateral movement. I'm still shocked. Summer traction and winter power!
To quote myself:
These things are seriously a game changer. Every single car that had an advantage over the vette in cold weather just lost it.
To quote myself:
My buddy is a race car driver and he replaced the stock Bridgestones, that were specifically designed for his Aston Martin Vantage N420, with the Super Sports. He said it's like driving a different car. The Michelins are that much better and he gets more miles out of them. He's incredibly hard on his tires.
While you can't get an accurate indication of tire life based on the rating, you can get an idea of how different tires will last. Looking at a Bridgestone with 280 rating tells me that the tire will last longer then the Michelin Cup with a 80 rating. Maybe the Bridgestone won't last 3.5 times longer the the Cup tire, but you know it will last longer.
I don't understand your comment about not running runflats on your car and rim damage. You can stick a plug in a run flat tire just as easy as a non run flat tire on the side of the highway, but if the tire, either run flat or non run flat, needs to be repaired or replaced at a tire shop 200 miles away, they both will have to be removed from the wheel.
Ok since Michelin does not make the SS in stock sizes, what size will fit my 05 coupe? If I buy new wheels then can I use one of the sizes that they do make? My discount store said the rep told him they will not be available until 2013.
