Installed HID Fog Lights Pics and How to.
Old 04-08-2012, 11:26 PM
JKbride
Support Corvetteforum!
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Default Installed HID Fog Lights Pics and How to.
Installed HID Fog lights I purchased from Corvette Mods here on CF and installed them today. Below are the DIY instructions and pics.
Before
After
Tools needed for the install:
-Small flat tip to help pull the pins from the plastic plugs
-T-20 Torque screw driver
-Rubbing Alcohol and Goof Gone (or Goo Off) to clean and prep the mounting location for the ballast
-Sissors to cut mounting tape and snip zip ties
-3M outdoor rated double sided tape (Kit comes with double sided tape, but I like the super sticky and durable 3M outdoor tape.
-Zip Ties (Kit comes with some but I ended up using a few more.
Step 1: Remove the front tire. Some opt not to do this, but for me it was easier just to take it off.
Step 2: Remove the fender liner plastic plugs that run near the wheel well and across the top of the fender liner.
Step 3: Pull the fender liner back enough to access the fog light housing.
Step 4:
Using your T-20 screwdriver remove the for screws holding the fog light bulb in place
Step 5:
Remove the OEM fog light, use care not to touch the bulb. I reused the foam shipping covers from the HIDs Kit to store my OEM's for a raining day.
Step 6:
Prep the ballast mounting location. The area it's mounted needs to be clean so the double sided tape will stick good. You don't want to ballast to come loose or it could cause your HID's to not work. This is an easy task, but an important one. Use Goo Gone (Goof Off) to remove the label on top of the housing followed by Rubbing Alchol to clean the top and remove any left over Goo Gone/ Goof Off.
Before Prep:
After Prep:
Step 7:
Install HID bulb. Use care not to touch the bulb. Place the blub into the fog light housing. Note the alignment of the "dog ears" on the bulb so they will align properly allowing the heads of the T-20 screws to secure them to the fog light housing.
Step 8:
Mount the ballast. Place your double sided tape on the underside of the ballast. Use a sharp object like an exacto knife to pre-lift a corner of the tape backing.
Picture of Ballast with red tape backing in place:
Backing removed (tape is gray)
Ballast installed on top of the fog light housing. Using the 3M tape and doing good prep work this unit feels like it is bonded forever to the fog light housing.
Step 9:
Connect HID's and Power to Ballast unit.
Here is the connection from the Ballast unit to the HID bulb
Here is the connection from the Ballast to the OEM power plug
Step 10: Test the lights. If they don't work, just unplug the OEM power to Ballast connection (see just above in step 9) and flip the OEM connection over and reconnect (I had to do this)
Step 11
Zip tie, reinstall the fender liner push pins and tire.
Hope you find this useful!
NoProxyFound (06-20-2017)
Old 04-08-2012, 11:33 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Looks good. Nice write-up.
Old 04-08-2012, 11:34 PM
Vegasr
Vegasr's Avatar
The new HID Fogs look great and awesome DIY write up!
Been hearing very good things about Corvette Mods, will have to order some of those from there.
Old 04-08-2012, 11:35 PM
Full Metal Jacket
Full Metal Jacket's Avatar
Wow think you Very much for this DIY !!!
I think I can do it now...
Looks sweet on your Vette!
Old 04-09-2012, 12:05 AM
0corvettemods1
Former Vendor
corvettemods1's Avatar
Great write up! Thanks for sharing!
On SALE NOW!
http://www.corvettemods.com/Corvette...it_p_5532.html
Old 04-09-2012, 12:47 AM
chevyc6z51
chevyc6z51's Avatar
Thoose dont
Match the low beams :/
Old 04-09-2012, 01:24 AM
EVRose
EVRose's Avatar
Nice write up. One tip though. You dont need to remove the 3 screws holding the bulb. Just loosen and turn the bulb till the tabs are free from the screws. Turn the new bulb into place and tighten screws.
Old 04-09-2012, 01:34 AM
george vee
george vee's Avatar
Received 1,069 Likes on 532 Posts
2015 C7 of the Year Finalist
Thanks for the great post, will install my kit this week.
Old 04-09-2012, 08:59 PM
JKbride
JKbride's Avatar
Good Point
Old 04-09-2012, 09:01 PM
JKbride
JKbride's Avatar
Originally Posted by chevyc6z51
Thoose dont
I can see why you would say that, but in truth in person they are dead on
Old 04-09-2012, 09:37 PM
su8pack1
su8pack1's Avatar
Old 04-09-2012, 10:21 PM
Mad*Max
Mad*Max's Avatar
Received 1,494 Likes on 815 Posts
bookmarked...thanks
Old 04-09-2012, 10:33 PM
dun4791
dun4791's Avatar
Nice write up, thanks...I just ordered
Old 04-09-2012, 10:40 PM
0corvettemods1
Former Vendor
Thanks for the orders guys! These are currently on promo for the forum
Old 04-09-2012, 10:48 PM
Mike7671961
Mike7671961's Avatar
This is a great post. I have the Hid fogs, low beams and backup light ready to install from corvettemods as well. This will be a great help.
Old 04-09-2012, 10:49 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Nicely done
Old 04-09-2012, 10:54 PM
Kadorja
Kadorja's Avatar
Damn those are a hell of a lot easier than the hack job I had to do on my Stang.
Might be ordering myself some in a few days. Got any other pics I want to see what they look like from a distance. I usually drove with headlights and fog lights on in my Mustang before... definitely easier to see the road and sidewalks.
Might grab some brighter reverse lights as well. My dad tinted the lenses which looks sick but the brighter light might help out a little. Good writeup too!
To Installed HID Fog Lights Pics and How to.
Old 04-09-2012, 11:49 PM
LS WON
LS WON's Avatar
Thanks for the write up and the pics
Are those fog lights 35watt or 55 watt?
The only problem would be is jacking up corvette and removing wheel.
Old 04-10-2012, 02:48 AM
chevyc6z51
chevyc6z51's Avatar
Why would they change in a pic? Nice write up btw
Old 04-10-2012, 09:22 AM
Polar Jet
Polar Jet's Avatar
Has anyone had a problem with mounting the ballasts on top of the housings? I seem to recall when researching it that it was considered a bad idea due to heat and the weight of the ballast causing the assembly to jiggle.
Going to install all my kit and 6000k lows in the next few days and want to do it right the first time.
Quick Reply: Installed HID Fog Lights Pics and How to.
