New Corvette, new engine problem on 2012 LS3 engine
Old 04-15-2012, 09:02 PM
viator
4th Gear
viator's Avatar
Default New Corvette, new engine problem on 2012 LS3 engine
Hello to all
I own a 2012 Carlisle Blue GS convertible, with only 537 miles on the car. Engine had the harmonic balancer fail. Main concern with so low mileage is possible internal engine damage, especially #1 main bearing and connecting rods on #1 and #2. Has anyone experienced a similar problem with such low mileage?
Old 12-16-2012, 04:25 PM
2012ls3vette
2012ls3vette's Avatar
Yes I did on mine 1000 miles and mine is a 2012. Was under warranty and I believe a recall on these
Old 12-16-2012, 04:27 PM
not08crmanymore
not08crmanymore's Avatar
go get it warrantied.end of story.They changed the design on the HB a while ago when they started failing 5 or 6 years ago.Diamond something or other in there now.Whatever damage your may have cause will be under warranty and therefore fixed for free.
Old 12-16-2012, 05:59 PM
Tom45
Tom45's Avatar
The only recall I have seen on the 2012 was for the rear hatch hinge.
Old 12-16-2012, 06:18 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
I gotta say a wow, 2012 and they're failing. You may want to see the thread on HBs. I'll find it and post it here.
http://forums.corvetteforum.com/c6-c...-balancer.html
Old 12-16-2012, 06:40 PM
hawkgfr
hawkgfr's Avatar
Received 1,212 Likes on 824 Posts
this....
Old 12-16-2012, 06:58 PM
brooklync5
brooklync5's Avatar
there is no recall on the harmonic balancer but there is a tsb if im not mistaken. these parts have been a problem since the c5 and have since carried over to the c6. not to worry OP your covered under warranty. It will take the dealer about a day to fix it as it requires a lot of work. My balancer failed at around 20k miles and even though i wasnt under warranty anymore being that my car is an 06 the dealer replaced it for FREE. Get it replaced and you should be all good. Funny thing with these balancers is that they can last 2 miles or 200,000.
Old 12-16-2012, 07:40 PM
EDinPA
EDinPA's Avatar
If your crank did not crack, you should be ok. I would only replace it with an ATI, even if it cost me.
see also:
Old 12-16-2012, 08:00 PM
EVRose
EVRose's Avatar
You guys realize this thread was started 8 months ago.
Old 12-16-2012, 08:10 PM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,250 Likes on 706 Posts
Probably all taken care of by now.
Old 12-16-2012, 08:24 PM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
or, it could be sitting in the north 40, under a couple of blue tarps, held down by old cinder blocks.... with flat runflats.
Old 12-16-2012, 08:25 PM
EVRose
EVRose's Avatar
Yeah, I would hope so.
Old 12-16-2012, 08:32 PM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
To New Corvette, new engine problem on 2012 LS3 engine
Quick Reply: New Corvette, new engine problem on 2012 LS3 engine
