Going from Firestones to Nitto or Hankook
2010 C6 Coupe with 8.5" x 18" front and 10" x 19" rear wheels. Currently have Firestone Wide Oval RFT's but want to got non RFT's and larger. Thinking about stepping up the tires two sizes front & rear to 265/35x18 front and 305/30x19 rear tires from the stock 245/40x18 front and 285/35x19 rears on the stock wheels.
Nitto Invo's don't have a 265/35x18 front tire, just a 255/35x18 but do have 305/30x19's. I know quite a few CF members have and love their Nitto Invo's, but I want to keep the two steps up ratio between front & rear tires.
Hankook Ventus V12 EVO tires come the the 265/35x18 and 305/30x19 rear tires. The price is $80.00 difference between the two with the Hankook's being the higher, not a deal breaker though.
Will probably go with the proper 2 steps up match with the Hankook's.
Hankook Ventus V12 EVO owners let me know how you like them.
Platinum Supporting Dealership
i have the hankooks on mine in those sizes.i removed and sold firestone wide oval rft's to install the hankooks. i love them. i have allways seen the nittos to be the more expensive tire though.
i am on my second set of rears. i have had the nittos before very nice tires , i prefer the hankooks lil cheaper seem to be a lil better in the rain (my car is dd)
really you cant go wrong with either tire.
both nitto and hankook seem to be a lil smaller than advertised. i have 305 on the rear . they look a lil wider than 305 nittos but i have never had or seen hankooks in a stock size so i cant say if they appear a lil narrower than stock gy's. most of it is the actual design of the itre the gy's have a wider look because the tire is more square where the sidewall meets the tread. the hankooks and nittos a more rolled from sidewall to tread.
KX, I've read where the Nitto's and Hankooks run a little narrower for the same size Goodyear or Firestone. I also want a little more tire width in the rear since I now have 400 rwhp, not a barn burner amount, but the current 285/35x19 Firestone Wide Oval RFT's don't quite grip when I get on it in 1st & 2nd gears (MN6). The two steps larger Hankooks will fit on the stock width rims also.
Stones;
front 8.2 tread width, 25.7 diameter
rear 10.4 tread width, 26.9 diameter
Hankook;
front 9.1 tread width, 25.3 diameter
rear 10.8 tread width, 26.3 diameter
Nitto;
9.96 overall width, don't know exact tread width, 24.96 diameter
12.36 overall width, don't know exact tread width, 26.22 diameter
I also understand you want to maintail 1:1 - 1:3 ratio front diameter to rear diameter. These choices do that.
Stones;
Hankook;
Nitto;
I just put on Michelin PSS. 305/30/19 and 255/35/18. I also replaced Firestones and the difference is amazing. I highly recommend them. The 305s fit perfectly and these 2 sizes give the closest to stock height difference.
I have the hankooks v12 evos and am pleased with them. Great grip in dry and wet, softer and quieter ride as well... Over a year of daily driving and they still have plenty left in them as well.
Are those Michelin Pilot Super Sports? Discount tire has them for $1440 for the 4 compared to Hankook Ventus V12 EVO at $1110 for the 4. Course, Michelin's are a GREAT tire.
I don't know where you got your info from but I have 265/35ZR18 Nitto Invo on the front of my Vette and 325/30ZR19 on the rear, when these wear out I will replace them with 275/35ZR18 and 345/30ZR19.
i love my hancook evo12's. awesome wet/dry traction and handling. great wearing tire as well. I wont be buying any other tire while i own my c6. my friend just put them on his porsche turbo. he loves them as well. handles better than his P zeros that were on there.
