Reading lights wont go off.....
All of a sudden, the reading lights on the rear view mirror wont go off. I have push the buttons on and off several times, and after several minutes of leaving the car, they are still on.
The button on the left panel does not dim or brighten the interior lights. What is wrong?
I have read the manual, and the dealer/service cant figure it out either. Jeez...if they cant do it who can?
Hopefully someone has an answer before my battery goes deadddddd.
It is the dreaded "knee switch" issue. You have possibly pressed the light switch near your left kneecap one too many times. Try pressing it in again (I think) and see what happens when you close the door.
Peter Wilson (11-02-2019)
Look in the owners manual on the page with the dash display for the location of this secret "on" button.......
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
you probably pushed in the **** on the left as it turns on interior lights, push it in again
wow there was nothing here when I started typing...my comp is so slow..... disregard mine then..... lol
Reading lights stay on
Well, after waiting quit a while, they finally went out.
As I stated above, I did push it in and out several times and it seemed to have not dimmed any lights at all. I did what the manual said to do. So anyway, fiddling around with it must have worked. Strange.
But thanks again, my Corvette family. I can always count on support from you....
All the lights are designed to go out after 20 minutes or so. So, you may have the same problem next time. The rear view mirror light switch is backwards, for me at least. On = out and off = in. That plus the dimmer switch thing makes it hard to get the right combination at times.
Well done. You get the award for the month so far.
Pushing (and releasing) that button one time turns on all interior lights. Pushing (and releasing) again turns off all interior lights, but map lights don't go out immediately.
You had previously pushed and released it once when you were detailing the inside of the car, but didn't realize it. Nearly all of us have done that sooner or later without realizing it.
This has been bugging me all week. could not figure out how to get these lights to shut off. Looked in the manual but not until I came to the forum did I get my solution.....ok so I feel a little dull to have bumped the switch with my knee and could not figure out why pressing the mirror buttons did nothing. Thanks for posting.
As BigJoe stated above, any/all the lights will go out after 20 minutes or so, when the computer goes to sleep/standby.
Great feature that would have saved me many jumps/re-charges over the years with other vehicles.
I just bought a new Grand Sport and I have the same issue. The courtesy lights will go out when you lock the car and go away but they will not go out while you are driving. Pushing in the switch for the interior lights makes no difference. It's becoming a real aggrivation to have the reading lights on all the time you are driving.
Any other suggestions beside going to the dealership?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
To operate properly start by insuring that the two buttons on the mirror are in the off position. Off = in (on = out)
Then get out and close door. The mirror lights should dim out after 20 seconds. IF THEY DO NOT DIM OUT, push the dimmer light switch on the left side of the dash 1 time.
Then get out and close the door. The mirror lights should dim out after 20 seconds.
Elmer
Elmer
It's not hit by the knee, as folks post, but while doing the cleaning chores inside the car. I did it three weeks ago.
