**AT LAST!** An affordable coil over conversion
Premium Supporting Vendor
Hello Everyone
I am pleased to announce that GMPARTSHOUSE.com is now a QA1 distributor! With that said we can offer you amazing prices on an high quality coil over system that is built in the USA.
These also now have FREE SHIPPING to the 48 states! (The website will charge shipping but we will adjust it off once we process the order)
and to make the deal even better . . . .
If you find a cheaper shipped price we will not only match it but will beat it by 10% of the difference! Email me at patrick@gmpartshouse.com for this offer
Corvette C5/C6 Single Adjustable Pro Coil System
Single Adjustable Suspension Designed Specifically for your C5/C6 Corvette
Simultaneously adjust your compression and rebound with QA1's Corvette C5/C6 Single Adjustable Pro Coil System.
•Made in the U.S.A.
•Easy, Bolt-In Installation
•No Cutting or Welding
•Coil-Over
•Ride Height Adjustable
•100% Dyno Tested and Serialized
•Rebuildable and Revalveable by the QA1 Factory or QA1 Authorized Service Centers
•Kit Will Lower the Vehicle
Prices
Single adjustable
Front pair 489.95
Rear pair 569.95
Front and rear set 1029.95
Double adjustable
Front pair 659.99
Rear Pair 749.99
Racing
Front set 529.99
To order simply give us a call or you can order online here
Also available double adjustable and racing configuations
please email me at patrick@gmpartshouse.com for pricing
•Made in the U.S.A.
•Coil-Over
Prices
Single adjustable
Front pair 489.95
Rear pair 569.95
Double adjustable
Front pair 659.99
Rear Pair 749.99
Racing
Front set 529.99
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
Just saw this:
"Note: This coil-over system will lower the Corvette at least 1.5" lower than stock. Not designed for stock ride height"
They are not adjustable enough to get it back up to stockish ride height?
I dont care where they are made at are they any good?
I don't see a valve for adjusting dampning/rebound?
By "single adjustable" do you mean only the ride hight is adjustable via the spring perch?
Any info on what the f/r springs are rated at?
_Sloth Whisperer_
You don't see the selector **** right there at the base of the coilover housing, front and center? Unless I'm fooled, that looks like a definite access point that wouldn't require tire removal.
Well I do now. I'll blame it on my tiny iPhone screen and not my tired ageing eyes.
I have the answer from QA1 on the height issue
Here is thier exact response:
Our coil-over units installed on all four corners will lower the car about 1/2" to 3/4" even at maximum ride height. In other words, they will not return the vehicle to stock ride height. The stroke on these units is very short (regardless of who manufactures the parts) so our recommendation is to limit lowering up to 1" lower than stock and no lower. While some people want to lower even more, any qualified handling and suspension person will tell you that going lower offers no improvement in handling, messes up the steering geometry, and creates alignment issues especially with camber.
Frankly the most important factor is corner weight both the C5s and C6s after any change in ride height. For proper handling it is imperative that the corner weights on both the front left and right sides are equal. I see a lot of guys talking about measuring form ground to fender lip or ground to jacking point to "balance" the car. While that may give them the "look" it doesn't maximize handling the way corner balancing does. Simply put, with the roll center so delicate in a Corvette, when you raise one side of the front it is transferring weight diagonally across the car to the opposite rear and vice versa. If the fronts aren't balanced the car will turn easier in one direction than the other in handling scenarios.
To answer your question directly, lowering the car much more than 1" will allow bottoming out depending on road conditions and type of driving being done.
Here is thier exact responce:
This is odd though. This response makes it sound like QA1 advises AGAINST lowering your car MORE than 1", but their website states, exactly as quoted,
"This coil-over system will lower the Corvette at least 1.5” lower than stock. Not designed for stock ride height."
So, from the above response, the MAX ride height will be 1/2"-3/4" lower than stock, but they also advise not to lower the car more than 1", making the adjustable ride height range less than 1/2"? Then, their website claims that the ride height will be AT LEAST 1.5" lower than stock?
What am I missing here?
Monitoring ride-height discussions
-also- Haven't seen any details on this so have to ask ...
Would I be correct in assuming these replace stock leaf springs?
-and-
Are they a simple bolt-in replacement for current shocks?
Thanks!!
-and-
Thanks!!
Great info, thank you.
You are correct. You would remve your leafs and bolt these in as simple as a shock replacement
